I have several questions regarding a workaround for the missing transmit connection on the MKR board.
I am working on a security device that can listen to the surroundings and alarm via SMS text if sound levels exceed preset limits. The SMS recipient is notified of course with preprogrammed messages. I then start a timer and if the alarm is not acknowledged within a preset time limit then another text is sent. This continues until another preset limit is reached at which time I wanted to place a voice call and, if answered, gate the speaker through to the caller so they could hear what was causing the alarm. I thought at first to simply identify the pin on the SARA-U201 chip and make a connection to it myself. If later revisions of the board include this feature then I could eliminate the modification at that time.
The other idea I had was to make a recording of the disturbance and store it on an SD card as a WAV file. Then when the call is connected I could send the WAV file through. This serves dual purposes in that the disturbance might not be there anymore when the timers finally call for the voice system to be activated and so the actual sounds that caused the system to trip are preserved. It also creates a physical record for forensic analysis at some point in the future.
So here are my requests:
- If there are any references to the procedure for creating a WAV file from a microphone board attached to the system I would appreciate a link.
- If there are references to the process for sending a WAV file through I would also appreciate a link.
- Would it be feasible to make the connection to the SARA-U201 I2C transmit line and approach it from that perspective?
Thanks for your attention and/or help.
Mike
