Working on the JawDuino needing the SoftRcPulseOut.h code
I am working on a talking skull and am trying this program. It is asking for SoftRcPulseOut.h. I have looked Hi and low and have not found it in any libraries. Does anyone have it or a work around?
Thanks,
Rodney
08-14-2016 Mike North This is a little proof of concept
to make a servo move in sync with audio.
#include <SoftRcPulseOut.h>
#define TEST_PIN 11 //pin 11 set to ground will kick off the servo sweep test
int audio_value = 0;
long lastMsg = 0;
long sleepWindow = 300000; //if 5 minutes go by with no signal, then put the servos to bed
SoftRcPulseOut servo;
volatile boolean servosEnabled = false;
volatile boolean ledsOn = true;
volatile unsigned long currentTime = 0;
volatile unsigned long lastLEDtime = 0;
unsigned long resetWait = 120000; //servos sleep if not changed within this time frame (120 secs)
set_minmax();
pinMode(TEST_PIN,INPUT); //pin 11 will be
digitalWrite(TEST_PIN,HIGH); //assign pull-up resistor
servo_test();
audio_updates(); //read sample from audio input and apply average to buffer
if(servosEnabled)
action(); //servos are handled in the action loop
SoftRcPulseOut::refresh();
if((millis() - lastMsg) > sleepWindow)
detach_servos();
void attach_servos()
{ // attach the pin to the servo object
servo.attach(2);
servosEnabled = true;
void detach_servos()
{ // detach the servo objects
servo.detach();
void servo_test()
if(digitalRead(TEST_PIN) == HIGH) return;
attach_servos();
for(int i = 0; i < 360;i++)
if(i < 180)
audio_value = i;
audio_value = 359 - i;
action();
for(int i = 0; i < 10; i++)
delay(1);
detach_servos();
void audio_updates()
audio_value = 0;
if(analogRead(A0) < 341) audio_value += 60;
if(analogRead(A1) < 341) audio_value += 60;
if(analogRead(A2) < 341) audio_value += 60;
if(audio_value > 0)
lastMsg = millis(); //save the time stamp from when we last had some action
if(!servosEnabled)attach_servos();
void action() {
if (!servosEnabled) attach_servos();
servo.write(audio_value);
void set_minmax()
//set the first parameter in the following functions to a number between 0 and 180.
//I used 92 and 72 in my tests to give about 20 degrees of motion.
//You may swap the large and small numbers to reverse direction.
//Just play with them, upload the code, then ground pin 11 to run the sweep test.
// Be sure to only play with these numbers while the jaw linkage is disconnected,
// otherwise, you risk hitting mechanical limits and damaging your linkage or servo!
servo.setMinimumPulse(map(92,0,180,512,2400));
servo.setMaximumPulse(map(72,0,180,512,2400));
Did you look at any of these?
You are good and thank you. I have not seen that sight before. I will book mark it and keep it close.
Rodney
