Working on with Arduino Mega 2560 and Adafruit Ultimate Breakout
Hi everyone! I'm working on with Arduino Mega 2560 and Adafruit Ultimate Breakout. I found this code (for Arduino UNO) and modified it a little bit so that I can use it to Mega 2560. My initial goal is to get the Counter and the Time. However, I am only getting the time and not the counter. I followed this:
MEGA "5V" to GPS "VIN"
MEGA "GND" to GPS "GND"
MEGA "18" to GPS "RX"
MEGA "19" to GPS "TX"
MEGA "12" to GPS "PPS" // I am trying to use Timer 1.
I also tried using 8, 48 and 49 as input pins but I still don't get any counter.
I'm a newbie here. Can you help me? Thank you!
Here is my code:
#define pin_led 13
#define pin_interrupt 2
#include "Arduino.h"
#include "Adafruit_GPS.h"
Adafruit_GPS gps;
// Global variables and defines
#define GPSECHO  true
uint32_t timer = millis(); //timer to read & print out the current stats
boolean usingInterrupt = false;
int cycle = 0;
volatile unsigned t1captured = 0;
volatile unsigned t1capval = 0;
volatile unsigned t1ovfcnt = 0;
volatile unsigned long t1time;
volatile unsigned long t1last = 0;
#define BUFFER_SIZE 32
volatile unsigned long int buffer[BUFFER_SIZE];
volatile byte head = 0;
volatile byte tail = 0;
 mySerial.begin(9600); // GPS communication at 9600 baud
 TCCR1A = 0x0;    // put timer1 in normal mode
 TCCR1B = 0x2;    // change prescaler to divide clock by 8
 // clear any pending capture or overflow interrupts
 TIFR1 = (1<<ICF1) | (1<<TOV1);
 // Enable input capture and overflow interrupts
 TIMSK1 |= (1<<ICIE1) | (1<<TOIE1);
 pinMode(8, INPUT);   //  Feed the signal in here
 byte newhead;
 if(head != tail) {
   newhead = (head + 1) % BUFFER_SIZE;
   Serial.println(buffer[newhead]);
   head = newhead;
    if (! usingInterrupt) {
    // read data from the GPS in the 'main loop'
    char c = gps.read();
    // if you want to debug, this is a good time to do it!
    if (GPSECHO){
    // if a sentence is received, we can check the checksum, parse it...
    if (gps.newNMEAreceived()) {
    // a tricky thing here is if we print the NMEA sentence, or data
    // we end up not listening and catching other sentences!
    // so be very wary if using OUTPUT_ALLDATA and trytng to print out data
    //Serial.println(GPS.lastNMEA());   // this also sets the newNMEAreceived() flag to false
    if (!gps.parse(gps.lastNMEA()))   // this also sets the newNMEAreceived() flag to false
    return;  // we can fail to parse a sentence in which case we should just wait for another
    // if millis() or timer wraps around, we'll just reset it
    if (timer > millis())  timer = millis();
    // approximately every 1 second or so, print out the current stats
    if (millis() - timer > 1000) {
    timer = millis(); // reset the timer
 printTime(); // to print the time
ISR(TIMER1_OVF_vect) {
  t1ovfcnt++;              // keep track of overflows;
ISR(TIMER1_CAPT_vect) {
 unsigned long t1temp;
 // combine overflow count with capture value to create 32 bit count
 //  calculate how long it has been since the last capture
 //   stick the result in the global variable t1time in 1uS precision
 t1capval = ICR1;
 t1temp = ((unsigned long)t1ovfcnt << 16) | t1capval;
 t1time = (t1temp - t1last) >> 1;
 t1last = t1temp;
 tail = (tail + 1) % BUFFER_SIZE;
 buffer[tail] = t1time;
void printTime()
 Serial.print("Time:");
 Serial.print(gps.hour); Serial.print(":"); // print out time (crudely!)
 Serial.print(gps.minute); Serial.print(":");
 Serial.print(gps.seconds); Serial.print('.');
 Serial.print(gps.milliseconds);
    Serial.print(" Counter:");
    Serial.print(t1capval);
Does this code even compile. I don't see that you have declared the mySerial object anywhere. Since you're using the hardware serial port Serial1 on your Mega, you should be using the library as demonstrated in the example sketches that have "HardwareSerial" in the name (find the example sketches under File > Examples > Adafruit GPS Library/b]). So take some time to study the examples, update your code accordingly, then if you still have any problems come back here to the forum and post the updated code as well as a description of the problem.
