Working principle of servo
I was trying to control the servo using just delayMicroseconds() function but the result wasn't so satisfy. As compare to the servo library, the amphere used for the library version is a lot much lesser and the it is more stable.
Library:
  • amphere 0.0++A
  • the shaft is tight, I can't move it
delayMicroseconds():
  • amphere up to 3.0++A
  • the shaft is very lossy, can be easily rotated
CODE of delayMicroseconds():
int x = 20;
const int servo = 9;
pinMode(servo, OUTPUT);
delay(3000);
digitalWrite(servo,HIGH);
delayMicroseconds(1000);
digitalWrite(servo,LOW);
delayMicroseconds(18000);
chunhou:
What happens if you try ....
delayMicroseconds(1500);
delayMicroseconds(20000 - 1500);
delayMicroseconds doesn't work if called with large arguments - try this:
 delay (20);
chunhou:
For long intervals like that you should not be using the delayMicroseconds() function because it blocks the Arduino from doing other things.
Have a look at how millis() is used to manage timing without blocking in several things at a time. The same technique can be used with micros().
...R
Thank you all, I tried and it worked finally. Yes, because the delayMicroseconds() doesn't work with large arguement.
