Hi everyone, fine?
This is my structure header file :
#ifndef PRESSION_H_INCLUDED
#define PRESSION_H_INCLUDED
typedef struct PRESSION PRESSION;
struct PRESSION
signed int si_Consignes[11];
signed int si_ValeursAdcParfaites[11];
unsigned int ui_TempIndex; // en °C/10
signed int si_TempPrises[3];
signed int si_ValeursPrises[11][3]; // 0 : TA @ 5°C
// 1 : TA @ 35°C
// 2 : TA @ 75°C
double ud_GainOffset[11][3]; // 0 : Gain @ 5°C // Pression->si_GainOffset[5][i] correspond a l'offset
// 1 : Gain @ 35°C
// 2 : Gain @ 75°C
double ud_DeriveGainOffset[11][3]; // 0 : Derive @ 5°C // Pression->si_DeriveGainOffset[5][i] correspond a la dérive de l'offset en température
// 1 : Derive @ 35°C
// 2 : Derive @ 75°C
signed int si_TempAmbiante;
signed int ValeurEnCours;
signed int OffsetEnCours;
double GainEnCours;
signed int ValeurCorrigee;
unsigned int ui_AdcRes;
unsigned int AdressesMembres[7];
void InitPression(PRESSION *pression, signed int si_ConsigneLow);
void GetValues(PRESSION *pression);
void CalculOffset(PRESSION *pression);
void CalculGain(PRESSION *pression);
void Process(PRESSION *pression);
#endif // PRESSION_H_INCLUDED
And this is the method which doesn’t work :
for(int j = 0; j < 3; j++)
for(int i = 0; i < 5; i++)
pression->sd_GainOffset[i][j] = (double)(pression->si_ValeursAdcParfaites[i][j]) / (double)(pression->si_ValeursPrises[i][j] + pression->sd_GainOffset[5][j]);
for(int i = 6; i < 11; i++)
error : suscripted value is neither array nor pointer nor vector.
I read somewhere I had to use double pointer, but don’t know how and if it works…
Thank’s guys!
