working with a #define statements
I thought that a #define statement was supposed to be global to a whole project, or is this not the case?
Here's what I'm doing to test. Firstly I put this as the very first line in my .ino file....
#define BANANA
Then in the setup phase of the .ino file I add this.....
#ifdef BANANA
  Serial.println("banana");
#else
  Serial.println("no banana");
#endif
The sketch compiles and uploads fine, when it runs I see the message 'banana'. all working as expected up to this point.
I then add a very similar statement to one of my functions inside a library of mine...
#ifdef BANANA
  Serial.println("more bananas");
#else
  Serial.println("no more bananas");
#endif
note - the library is #include'd in the .ino file after the line '#define BANANA'
This compiles and uploads ok, but now I get the additional printout 'no more bananas'
I thought that a #define statement was valid from that point forward, so putting it right at the top of the .ino file (specifically before the #include of the library that it's used in) would mean it should be visible inside that library. Or have I misunderstood something?
thanks
I think you are running afoul of the Arduino IDE munging your .ino int C++ files. As a test, try putting an 'int test = 0;' as the first line.
KeithRB: I think you are running afoul of the Arduino IDE munging your .ino int C++ files. As a test, try putting an 'int test = 0;' as the first line.
not quite sure what you mean, but I've tried adding the line you suggested and I get exactly the same results.
I've also tried adding the lines to a number of different libraries and sketches - same results each time. I'm using arduino 1.6.5 if that's relevant.
cheers
When you place this inside of loop() what happens?
ifdef BANANA
endif
LarryD: When you place this inside of loop() what happens?
ifdef BANANA
endif
I get lots of bananas (as expected). so I guess that means the original #include scopes the whole of the .ino file
And if you comment this? //#define BANANA
You have placed your "more banana" #define in the .cpp and NOT in the .h Only the .h is included when you use a #include the cpp is NOT copied in to the .ino
This is standard C/C++
Mark
ifdef BANANA
endif
Ok, think I’ve cracked it (this might be what holmes4 was talking about – thanks)
This is my pseudo code as it stands….
#define BANANA
#include <Library1.h>
#include <Library2.h>
#include <Library3.h>
#include <Library4.h>
#include <Library5.h>
#ifdef BANANA
#else
#endif
  // this func contains my test for BANANA
  Library5.func();
The test in setup() correctly picks up the BANANA, but the one inside Library5.func() doesn’t.
However, if I move my “#define BANANA” Statement to the first line of Library1.h then it seems BANANA is visible to my .ino file and the code in Library1.cpp and the code in Library5.cpp – which is what I want. But if someone could provide an explanation that would be great too!
The C++ compiler moves program lines around, adds function prototypes, etc. and can cause unexpected behavior like what you are observing.
This seems to be a recently introduced problem. I had a similar problem (enum statements that wouldn't work), which was fixed by using an older version of the IDE.
If your "libraries" are truly libraries (i.e. - they consist of a .h file and a .cpp file), then they get compiled separately from the .ino, so they will never see ANY #defines you put in the .ino. The compiled libraries and compiled .ino file are joined only a link time, LONG after the #defines have been tossed away. If you want both the sketch and one or more libraries to "see" #defines, then those #defines must be defined in a separate .h file that is #included into both the sketch AND the libraries.
Regards, Ray L.
OhMyCod: I thought that a #define statement was supposed to be global to a whole project, or is this not the case?
It's not the case. Google "C preprocessor".
Totally wrong! This is standard C/C++ behavior.
  1. include copies the the file "included" into the file in which the #include occurs. Think control-c control-v. It's basically just a copy and paste.
  2. All C/C++ compilers work on 1 C/C++ file at a time
The result is that your #define effectively has global /file scope.
Mark
holmes4: Totally wrong! This is standard C/C++ behavior.
Mark
Not even global/file scope, as that suggests the #define is "seen" by the entire file. It is not "seen" until AFTER the #define appears in the pre-processed source file. #defines cannot be forward-referenced.
Regards, Ray L.
Nor can anything. int's, functions etc.
Mark
PS Ray - which part of my post did you object to? It's both bad form and confusing to copy the whole post!
M
RayLivingston: If your "libraries" are truly libraries (i.e. - they consist of a .h file and a .cpp file), then they get compiled separately from the .ino, so they will never see ANY #defines you put in the .ino.
They are
RayLivingston: If you want both the sketch and one or more libraries to "see" #defines, then those #defines must be defined in a separate .h file that is #included into both the sketch AND the libraries.
I seem to have achieved the same thing with a slightly different method (see my post at 10:45). I have added my #define as the top line of the first #included library (library1.h). The #define seems to be in scope for ALL of the subsequent libraries, and the .ino file itself.
Isn't the best solution just to create a file called 'global.h' for all the #defines that require a global scope and then #include this as the first line in my .ino file?
