working with incoming bytes
Hi, I have an issue trying to use a switch statement with a serial read. (I know just one read is not usually enough bit I am keeping it down to brass tacks).
Basically, when I send a byte (like 5) through the PC serial port, the switch statement always goes to default. Why wont it recognise the 5. It will echo 5 back through default, but not recognise it as an int.
case -1 when nothing read, of course works.
define STEP_UP 3
define STEP_DOWN 4
define HALT 5
define MOVE_UP 6
define MOVE_DOWN 7
void loop() { s_incoming = Serial.read (); if (s_incoming == 5) Serial.println ("5 received");
switch (s_incoming) { case STEP_UP: s_incoming = 0; // delayMicroseconds(STEP_DELAY); Serial.println ("went up a step"); //DEBUG ONLY break;;
case STEP_DOWN: s_incoming = 0; //delayMicroseconds(STEP_DELAY); Serial.println ("went down a step"); //DEBUG ONLY break;
case HALT: s_incoming = 0; Serial.println("STOPPED"); break;
case MOVE_UP: //do these on a for loop Serial.println("Moving UP X steps"); s_incoming = 0; break;
case MOVE_DOWN: // do these on a for loop Serial.println ("moving DOWN X steps"); s_incoming = 0; break;
case -1: //Serial.println("no action"); break; //do nothing
default: Serial.write(s_incoming); s_incoming = 0; } //Serial.write(s_incoming); }
5 the byte (0x05) or 5 the char ('5')?
like this:
byte s_incoming;
#define STEP_UP '3'
#define STEP_DOWN '4'
#define HALT '5'
#define MOVE_UP '6'
#define MOVE_DOWN '7'
  if (Serial.available())
    if (s_incoming == '5')
      case STEP_UP:
        break;;
      case STEP_DOWN:
      case HALT:
        s_incoming = 0;
        s_incoming = 0;
        s_incoming = 0;
      case -1:
        break; //do nothing
      default:
        s_incoming = 0;
the "echo" was the char you sent... not an echo.
‘5’ is not the same as 5.
5 is the code for control-E in ASCII, character constants are represented by integer values (char is actually an integer type).
For instance 'A' == 65, 'B' == 66, etc, '!' == 33.
You have to know the difference between a character and its integer code. Normally with a serial terminal application you are handling characters so typing a '5' is character '5', not integer value 5.
Serial.read() returns the character value, which you can treat as a character or an integer, so you need to be clear which at all times.
GUYS GUYS!! You all ort of got it.. a Syntax error in the switch. It schould of course be '5' not 5 .. nasically I have to make the int a char. I can put a variable in there by declaring the variables as const char or as MArkT says #define 65 for "A" etc. Simple DOH!!
Thanks to everyone.
MikeDutton: ...declaring the variables as const char or as MArkT says #define 65 for "A" etc. Simple DOH!!
careful careful
"A" != 'A'
