I am working on a project that I have prototyped with the Mega 2560, and everything works as it should. I now need to shrink it down to the size of a 9volt battery.
Which program should I use to do this? I've seen video's of Eagle, but do not know if manufactures prefer eagle. Can it be done, which program should I use, and is there a schematic available or chip even that has the mega's features already incorporated that is shrunken down?
I talked to a manufacture the other day, and they said they recommended that I let them build it from the ground up, not using the mega 2560 schematics. They said the cost would be much cheaper to get the prototype made, but I would still need to program it myself. The problem I have with this is that you have to select which board you are using on the IDE and if I have a custom board, I do not know if I can use the debugging tools that arduino offers that I am accustom to.
It seems arduino is the best board for prototyping, but where do you go from there? I see smaller boards like the nano, and mini, but none of them seem to have the memory and number of pins that the mega has.
Does anyone have any suggestions? If I knew how to use eagle how long would it take to design a multi layered mega2560 that is significantly smaller (of course I wouldn't be able to hand solder anything to it, but at this level I wouldn't want to). Does anyone have contact information of a manufacture that can make the multi level board for me at a reasonable price? What program do you recommend that I use to design the board? What if I get the schematics drawn, can I get the board made for a few hundred? Does anyone know of anyone that can do the schematics if I give them the schematics of everything I am using?
