Working with pointers
The compiler gives an error with this code. It does not like the (req == “/”) comparison.
Please tell me how to fix it.
*char HTTP_req[REQ_BUF_SZ] = {0};
int requestType = 0;
requestType = findRequestTypet(HTTP_req, REQ_BUF_SZ);
int findRequestType (char* req, char length)
Serial.println(req[0]);
for (int i = 0; i < length; i++)
	// find first "/" in req
	if (req[i] == "/")
		if ((req[i+1] == int("c")) && (req[i+2] == int("-")))
			return 1;
			return 0;
if (req[i] == '/')
Hands off the Shift key. Single quotes ( ' ) for individual characters like this, don't cast the strings to ints. You need to fix more than just that line.
Because "/" is a pointer to a two element char array consisting of '/' and '\0 '. This array is stuffed in memory someplace.
If you want a string comparison use strcmp(). If you want a character comparison use '/'
Jiggy-Ninja:
Got it. Thanks to all.
I think I may still be doing something wrong.
I am gettinga requestType of 3 when I should be getting 0.
Revised code:
		if (req[i] == '/')
			if ((req[i+1] == 'c') && (req[i+2] == '-'))
				//TODO: make sure we have all numbers
            			char commandNumber[5];
            			commandNumber[0] = req[i+3];
            			commandNumber[1] = req[i+4];
            			commandNumber[2] = req[+i+5];
            			commandNumber[3] = req[i+6];
            			//commandNumber[4] = "0";
            			int b = atoi(commandNumber);
            			return b;
				return 0;
You need to nul terminate commandNumber. The last character needs to be '\0' - and not '0' which is ascii zero.
The serial monitor does not show me the slash when it should so I guess it is not getting there at all.
if (req[i] == '/')
Serial.print ("Character:  ");
    Serial.println(HTTP_req[i]);
You're not printing the thing you're comparing, it seems to me
if (HTTP_req [ i ] == '/' )
--Michael
edit: oops. forgot about the italics thing.
AWOL:
I added the serial printout just to test if it is getting inside the if statement which it should but is not because there is no serial monitor output.
I'd love to spend longer on this with you, but if you can't be bothered to post anything but uncompilable snippets, it's just a waste of time.
I'll try once more. You've declared your array
HTTP_req[i]
not
req[i]
best,
Michael
mjward:
--Michael
I fixed it. the serial statement should be
Serial.println (req[i]);
Oh. I see now that you're passing a pointer to the array.
Is there a typo in this line? requestType = findRequestTypet(HTTP_req, REQ_BUF_SZ);
(that last lower case t at the end of findRequestTypet)
--Michael
mjward:
Oh. I see now that you’re passing a pointer to the array.
–Michael
Yes, thanks. Good catch. There is a typo there because I entered it manually to shorten up the code for here.
It is OK in my program.
And yes, I am using req because it is in the scope of the procedure although I could use HTTP_req because it is global.
I now know what the problem is.
It is the length passed to the procedure.
Please suggest a change.
Use strlen() to calculate the length in the function.
KeithRB:
Thank you all so much.
