Working with servo motor
Hello there. Im currently working on a project that are using servo motor. I intend to do an automated rain sensing wiper. whenever there is rain, the wiper will be automatically turn on. I managed to make it to work for now. I wonder would it be possible if it is not raining and the wiper is currently moving, i send an order to ask the wiper to stop?
here is an example of the code
#define Grove_Water_Sensor 13 // Attach Water sensor to Arduino Digital Pin 13
#include <Servo.h>
#include <LiquidCrystal.h>
#include <DHT.h>
#include "DHT.h"
#define DHTPIN A0     // what pin we're connected to
#define DHTTYPE DHT11   // we are using the DHT11 sensor
Servo myservo;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
DHT dht(DHTPIN, DHTTYPE);
int pos = 0;    // variable to store the servo position
   pinMode(Grove_Water_Sensor, INPUT); // The Water Sensor is an Input
   myservo.attach(3);
  for (int DigitalPin = 7; DigitalPin <= 9; DigitalPin++)
  pinMode(DigitalPin, OUTPUT);
  lcd.begin(16,2);  //16 by 2 character display
dht.begin();
   if( digitalRead(Grove_Water_Sensor) == HIGH) {
      for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
                                            // in steps of 1 degree
    myservo.write(pos);                     // tell servo to go to position in variable 'pos'
    delay(15);                              // waits 15ms for the servo to reach the position
     for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
    // Reading temperature or humidity takes about 250 milliseconds!
    float h = dht.readHumidity();
    float t = dht.readTemperature();  // Read temperature as Celsius (the default)
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Temp: ");
    lcd.print(t);  //printing temperarture to the LCD display
    lcd.print("'C");
    lcd.setCursor(0,1);
    lcd.print("Humid: ");
    lcd.print(h);  //printing humidity to the LCD display
    lcd.print("%");
   else {
      myservo.detach();
Presumably the sensor returns HIGH when it detects water. What happens at present when the sensor returns LOW ? What do you want to happen ?
UKHeliBob:
If the sensors returns LOW, the wiper would turn off (if it is previously on) or the wiper remains off (if it is previously off). And after 1 minute delay, the device would loop back right from the beginning
Sorry, but I am not getting what you want to happen.
It seems to me that if it is raining then the wipers should sweep back and forth but when it is not raining they should go to a parked position and not just stop. Is that right ?
Also, presumably independently of the wipers, the temperature and humidity should be displayed, perhaps continuously, perhaps every so often. Is that right ?
