I am having trouble setting up the libraries so that the example code will compile.
It appears I have failed to load the IS31FL3731 libraries though I have loaded them per the instructions.
It would be a help to work with someone that has programmed to this display and compare setups. I am very close to getting something to work once these library issues are resolved.
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here as it prevents some combinations of characters in code being interpreted as HTML commands such as italics, bold or a smiley character, all of which render the code useless
If the code exceeds the 9000 character inline limit then attach it to a post
