Working with the *old* Adafruit TFT libraries and changing pin assignments
Why don't you post the links as requested?
And say exactly which Shield pin you want to connect to which PORT pin. e.g. LCD_D6 to PA7
Life is considerably simpler if you use contiguous bits in PORTA. The library is already prepared for that.
Yes, you can use random pins. The macros become a bit horrible and slow. But hey-ho, if that is what you want. If you designed your own pcb, you would route the pins conveniently.
David.
