Working with two analog inputs. Trouble with lm35 and LDR sensor.
Hello everyone.
I have a trouble with my LM35 thermometer project and can't figure out it by myself.
A0 - get LM35 signal;
A1 - get LDR with (internal pull-up);
Everything is working very good until that times when I enable LDR sensor on A1 in the code. Temperature readings begin chaotic dance from 22 to 27 C, when normal temerature in my room is about 25 C. Replacing sensors on the others pins, for example A3, A4 doesn't help.
I spent all night on searching to find out where is problem and nothing... Where is the bug? If you have comments about "how to make my code better", please share.
On this video reading LDR is closed in code, so LDR handling is not enabled to executing.
// Reading LDR (This is a trouble place)
// LDR_Bar = (analogRead(LDR_PIN) / BAR_SCALE);
// LDR_Block = analogRead(LDR_PIN);
and now you can see behavior when these lines are uncommented
Project code:
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
#include <SPI.h>
// pin 3 - Serial clock out (SCLK)
// pin 4 - Serial data out (DIN)
// pin 5 - Data/Command select (D/C)
// pin 6 - LCD chip select (CS)
// pin 7 - LCD reset (RST)
Adafruit_PCD8544 display = Adafruit_PCD8544(3, 4, 5, 6, 7);
float tempc, voltage;
int LDR_Bar, LDR_Block, LM35_Bar, LM35_Block;
long prev_millis;
#define LDR_PIN A1    // pin for LDR
#define LM35_PIN A0   // pin for LM35
#define UPDATE_TIME 3000
#define BAR_SCALE 12.19047619
static const unsigned char PROGMEM thermometer [] =
        B00100000, //   #
	B01010000, //  # #
	B01010000, //  # #
	B01010000, //  # #
	B01010000, //  # #
        B01010000, //  # #
	B01010000, //  # #
	B01110000, //  ###
	B01110000, //  ###
	B01110000, //  ###
	B11111000, // #####
	B11111000, // #####
	B11111000, // #####
	B01110000, //  ###
  pinMode(LDR_PIN,INPUT);
  pinMode(LM35_PIN,INPUT);
  // Enable pull-up resistor on the Analog Pin A1
  digitalWrite(LDR_PIN, HIGH);
  // Init
  display.begin();
  // Show Adafruit splashscreen
  display.display();
  // Clear the screen and buffer
  display.clearDisplay();
  // Contrast for the display
  display.setContrast(60);
void ClearDisplay() {
  // Clear display
  display.display();
  delay(300);
void DisplayTemperature() {
  display.setCursor(0, 0);
  display.setTextColor(BLACK);
  display.setTextSize(1);
  display.print("Temperature:");
  // Draw bitmap here
  display.drawBitmap(0, 10, thermometer, 5, 14, BLACK);
  display.setCursor(8, 10);
  display.setTextSize(2);
  display.print(tempc);
  display.println("C");
void DrawGraphicBar() {
  // Graphic bar is awesome!
  display.drawRect(0, 25, 84, 6, BLACK);
  // 2px Bar for LM35
  display.drawFastHLine(0, 26, LM35_Bar, BLACK);
  display.drawFastHLine(0, 27, LM35_Bar, BLACK);
  // 2px Bar for LDR
  display.drawFastHLine(0, 28, LDR_Bar, BLACK);
  display.drawFastHLine(0, 29, LDR_Bar, BLACK);
void DrawBlockTemperatureUnit() {
  display.setCursor(0,32);
  display.setTextColor(WHITE, BLACK);
  display.print("T/U");
  display.print(":");
  display.println(LM35_Block);
void DrawBlockTemperatureVoltage() {
  display.setCursor(0,41);
  display.print("T/V");
  display.print(":");
  display.print(voltage);
void DrawBlockLDRUnit() {
  display.setCursor(42,32);
  display.print("LDR");
  display.print(":");
  display.println(LDR_Block);
  if (millis() - prev_millis >= UPDATE_TIME) {
    prev_millis = millis();
    // Let's read and calculate temperature
    voltage = (4.65 * analogRead(LM35_PIN)) / 1024;
    tempc = (voltage * 1000) / 10;
  // Reading LM35
  LM35_Bar = (analogRead(LM35_PIN) / BAR_SCALE);
  LM35_Block = analogRead(LM35_PIN);
  delay (50);
  //LDR_Bar = (analogRead(LDR_PIN) / BAR_SCALE);
  //LDR_Block = analogRead(LDR_PIN);
  delay (50);
  // Serial.print ("LM35:");
  // Serial.println(LM35_Block);
  // Serial.print ("LDR:");
  // Serial.println(LDR_Block);
  // delay(200);
  DisplayTemperature();
  DrawGraphicBar();
  DrawBlockTemperatureUnit();
  DrawBlockTemperatureVoltage();
  DrawBlockLDRUnit();
  ClearDisplay();
Thanks for help.
Typically, one would read the temperature sensor a number of times, and average the readings.
Do the same, then, with the light sensor.
Oh, yes I have plan to do it.
Just received an answer on the russian arduino community. I should have a filtering capacitor from out LM35 to ground.
It's working, now flickering is very tiny.
Also I have looked into the web and datasheet (Why I didn't do it before?) and find out as good solution is to have a pull-down to ground 4,7-10 k resistor from lm35 to avoid noise on analog inputs.
