Hi!
I’m working on something like compass with tilt compensation (nevermind).
I made program and tested it on arduino Nano (since there is no problem with serial controll). After some calibration and test i’ve decide to move it to attiny.
And something went wrong… it stoped to work. I’ve modified somehow the sketch to debug it. As i have connected LED’s to it already, i made function to blink and found out that the problem is with HMC5883L (compass) - stops on “!compass.begin()” loop connected in parallel with MPU6050 (accelerometer + gyro).
Can there be something that makes it not working with different cpu in scetch or library?
scetch
#include <Wire.h>
#include <HMC5883L.h>
#include <MPU6050.h>
HMC5883L compass;
MPU6050 accel;
// AtTiny
const int lLed = 1;
const int cLed = 3;
const int rLed = 4;
const int serialOn = 0;
//Nano
/*const int lLed = 3;
const int cLed = 5;
const int rLed = 6;
const int serialOn = 1;*/
int head = 0;
if(serialOn){
pinMode(lLed, OUTPUT);
pinMode(rLed, OUTPUT);
pinMode(cLed, OUTPUT);
//blinkOnce();
// Initialize MPU6050
while(!accel.begin(MPU6050_SCALE_2000DPS, MPU6050_RANGE_2G)){
delay(100);
//blinkOnce();
// Enable bypass mode
accel.setI2CMasterModeEnabled(false);
accel.setI2CBypassEnabled(true) ;
//accel.setSleepEnabled(false); //default: false
//blinkOnce();
// Initialize Initialize HMC5883L
while (!compass.begin()){
delay(100);
blinkOnce();
blinkOnce();
// Set measurement range (default)
//compass.setRange(HMC5883L_RANGE_1_3GA);
// Set measurement mode (default)
//compass.setMeasurementMode(HMC5883L_CONTINOUS);
// Set data rate (10b), default - 15HZ
//compass.setDataRate(HMC5883L_DATARATE_30HZ);
// Set number of samples averaged (10b), default - 1
compass.setSamples(HMC5883L_SAMPLES_8);
// Set calibration offset. See HMC5883L_calibration.ino
compass.setOffset(17, -64);
blinkOnce();
void blinkOnce(){
digitalWrite(lLed, HIGH);
digitalWrite(cLed, HIGH);
digitalWrite(rLed, HIGH);
delay(100);
digitalWrite(lLed, LOW);
digitalWrite(cLed, LOW);
digitalWrite(rLed, LOW);
delay(100);
Vector mag = compass.readRaw();
Vector acc = accel.readRawAccel();
//Vector acc = {0.0, 0.0, 0.0};
//normAccel.YAxis;
float ax,ay,az,cx,cz,cy;
const float multip = 0.005493164/57;
//ay-z in radians
ax = acc.XAxis * multip;
ay = acc.YAxis * multip;
az = acc.ZAxis * multip;
cx = mag.XAxis;
cy = mag.YAxis;
cz = mag.ZAxis;
float xh,yh;
/*Serial.print("AX: ");
Serial.print(ax);
Serial.print(" AY: ");
Serial.print(ay);
//Serial.print(" AZ: ");
//Serial.print(az);
Serial.print(" | ");*/
if(serialOn){
//Serial.print("CX: ");
Serial.print(cx);
//Serial.print(" CY: ");
Serial.print(" ");
Serial.print(cy);
//Serial.print(" CZ: ");
//Serial.print(cz);
//Serial.print(" | ");
xh=cx*cos(ay)+cy*sin(ay)*sin(ax)-cz*cos(ax)*sin(ay);
yh=cy*cos(ax)+cz*sin(ax);
//xh=cx*(cos(ax) - 0.85)/0.15;
//yh=cy*(cos(ay) - 0.85)/0.15;
/*Serial.print("ayf: ");
Serial.print(ayf);
Serial.print(" axf: ");
Serial.print(axf);
//xh=cx*ayf+cy*ayf*axf-cz*axf*ayf;
//yh=cy*axf+cz*axf;
/*if(serialOn){
Serial.print("cos ay: ");
Serial.print(cos(ay));
Serial.print(" cos ax: ");
Serial.print(cos(ax));
Serial.print(" sin ay: ");
Serial.print(sin(ay));
Serial.print(" sin ax: ");
Serial.print(sin(ax));
head=atan2((double)yh,(double)xh) * (180 / PI) -90; // angle in degrees
head += 3;
if (head<0){head += 360;}
//head += 360;
/*int ax,ay,az,cx,cz,cy;
MMA7660.getValues(&ax,&ay,&az);
HMC.getValues(&cx,&cz,&cy);
float xh,yh,ayf,axf;
ayf=ay/57.0;//Convert to rad
axf=ax/57.0;//Convert to rad
xh=cx*cos(ayf)+cy*sin(ayf)*sin(axf)-cz*cos(axf)*sin(ayf);
yh=cy*cos(axf)+cz*sin(axf);
var_compass=atan2((double)yh,(double)xh) * (180 / PI) -90; // angle in degrees
if (var_compass>0){var_compass=var_compass-360;}
var_compass=360+var_compass;
return (var_compass);*/
/*if(serialOn){
Serial.println(head);
if(head < 10 || head > 350){
}else if(head >= 10 && head < 180){
}else if(head <= 350 && head >= 180){
delay(100);
//blinkOnce();
HMC lib attached.
HMC5883L.cpp (5.78 KB)
