Hi Folks,
I found some code that works to transmit the required signal to an RX-2B RC receiver, the code works great from my Uno but when I tried to run it from my Yún nothing happens.
The code has definitely uploaded as I tested with an LED and the pin is getting a HIGH voltage written to it.
Does anyone have any idea what the issue might be? Code below.
Thanks.
* Control Realtek RX2 (RX2 -G) RC Receiver with Arduino
* @author Mircea Diaconescu, Octomber 28, 2013
* @source https://github.com/dimircea/
* GPL v3 License
* Many cheap RC toys are based on TX2 / RX2 transmitter / receiver ICs.
* This Arduino sketch allows to replace the TX2 based Remote Control with Arduino.
* Just one single pin is used from the Arduino board.
* Connect Arduino pin 10 to the solder point where the toy antenna is connected or to the toy antenna cable.
* One can replace pin 10 with other free digital pin available on the Arduino board.
* TX-2B/RX-2B datasheet: http://www.datasheetarchive.com/dl/Datasheet-035/DSA0017137.pdf
/** Functions (aka W1) - as defined by the IC datasheet */
#define COMMAND_ENDCODE 4
#define COMMAND_FORWARD 10
#define COMMAND_FORWARD_TURBO 16
#define COMMAND_TURBO 22
#define COMMAND_FORWARD_LEFT 28
#define COMMAND_FORWARD_RIGHT 34
#define COMMAND_BACKWARD 40
#define COMMAND_BACKWARD_RIGHT 46
#define COMMAND_BACKWARD_LEFT 52
#define COMMAND_LEFT 58
#define COMMAND_RIGHT 64
//output pins
#define ANTENNA_PIN 9
/** Initialize the Arduino data and pin */
pinMode( ANTENNA_PIN, OUTPUT);
/** Loop code */
// add here your commands to control the RX2 module...
// for test purposes, here a continuous forward command is sent
sendCommand( COMMAND_FORWARD);
/** Send command to the RX2 IC */
void sendCommand( int command) {
int w1 = 0, w2 = 0;
/** start code sequence 4 x W2, ~625Hz, Duty Cycle 75% */
for ( w2 = 0; w2 < 4; w2++) {
digitalWrite( ANTENNA_PIN, HIGH);
delayMicroseconds( 1200);
digitalWrite( ANTENNA_PIN, LOW);
delayMicroseconds( 400);
/** function code sequence, n x W1, ~1.25KHz, Duty Cycle 50% */
for ( w1 = 0; w1 < command; w1++) {
