WorldClock_NeoMatrix8x8 -what does this mean!
Arduino: 1.6.4 (Windows 8.1), Board: "Pro Trinket 5V/16MHz (USB)"
WordClock_NeoMatrix8x8.ino: In function 'void setup()':
WordClock_NeoMatrix8x8:157: error: 'class DateTime' has no member named 'unixtime'
WordClock_NeoMatrix8x8:162: error: 'class DateTime' has no member named 'unixtime'
Moon.ino: In function 'void mode_moon()':
Moon:85: error: 'class DateTime' has no member named 'unixtime'
calculateTime.ino: In function 'DateTime calculateTime()':
calculateTime:24: error: 'class DateTime' has no member named 'unixtime'
calculateTime.ino: In function 'boolean checkDst()':
calculateTime:49: error: 'class DateTime' has no member named 'dayOfTheWeek'
Can someone help me understand this string of code and where i need to fix it please, its a school project and I'm really stuck.
WordClock_NeoMatrix8x8.ino (6.05 KB)
What library are you using? Link to it preferred. Are you using the example from that library?
here's the error message
Arduino: 1.6.4 (Windows 7), Board: "Pro Trinket 5V/16MHz (USB)"
WordClock_NeoMatrix8x8:157: error: 'class DateTime' has no member named 'clock'
WordClock_NeoMatrix8x8:162: error: 'class DateTime' has no member named 'clock'
Moon:85: error: 'class DateTime' has no member named 'clock'
calculateTime:24: error: 'class DateTime' has no member named 'clock'
enabled in File > Preferences.
im a noob when it comes to programming on arduino need some help!
here the links to the lib i used:
WordClock_NeoMatrix8x8.ino (6.04 KB)
    theTime = theTime.clock() + 150;
So, why do YOU assume that you can call a method that doesn't exist?
Why are you trying to assign a number to an instance of the DateTime class?
the libraries i used for this project.
i'm not able to program it please can you get back to me because i need to submit it for my school finals.
i've been trying for months to get this to work.
Overview | NeoMatrix 8x8 Word Clock | Adafruit Learning System project link
i have linked the .ino file for more reference.
help me please. get back to me asap.
PaulS:
    theTime = theTime.clock() + 150;So, why do YOU assume that you can call a method that doesn't exist?
i haven't written any of this this was from the site and i'm just following along all the links are in the post above.
