Woud this work for an LED?
Whould this program work to turn on an LED? I wrote this based off of a previous post. I want to use this for another program.
int pin12 =12;            //LED Pin
int pin2 =2;            //Button Pin
int pin2status;
      Serial.begin (9600);
      pinMode (pin12, OUTPUT);      //sets LED pin as OUTPUT
      pinMode (pin2, INPUT;            //sets button pin as INPUT
      pin2status = digitalRead(pin2); //sets variable for pin2
void loop ()
      pin2status = digitalRead(pin2); //reads button pin
      if (pin2status == LOW)
      }                        //do nothing
      if (pin2status == HIGH)            //if button is pressed
            digitalWrite (pin12,HIGH);      //then turn on LED
If this works how could I modify it so when the button is pressed a command is sent to a MAX232 (or similar chip) and out through hyperterminal?
I noticed this tutorial:
But I'm not sure how to incorporate the SW commands into this program.
Also, is there a way to display the output and input to the MAX232 on an LCD?
I haven't received my arduino board yet so I can't test this program out. Please help if possible.
Just realized I spelled would wrong a couple of times. LOL
Yes, it would turn a LED on, but not off again.
As AlphaBeta says, it would turn on but not off again.
