Would I be able to tell that a multiplexer can only ouput one value at a time ?
So, I'm trying to make a sort of midi controller using multiplexers.
Basically, I want a button press on a multiplexer to play a note on my arduino. I'm to understand that one multiplexer can only send one output value at a time. So, if I were to press more than one button at the same time (a chord) would I be able to hear the delay between the two notes being read?
I'm really new to arduino and electronic stuff, so any help is GREATLY appreciated. Thanks!
You are quite correct you can only get one output at a time from a multiplexer. Also be aware that there is no such thing at pressing two buttons at the same time.
However while there would be a delay it will be so short you will not be able to perceive it.
A lot depends on how quickly your multiplexer is scanning, and how you have written the software.
