hello
this is my first project/ I got this code here runs fine but after few second or may be when the code ends it turns off.
For example a when i put a simple code for a led ... why the led can't stay on forever instead it turn off and lights back
I would like this to stay on let say for ever continuously. there was a issue with wiring diagram that I resolved.
I got this code from; http://civicjunkie.com/main/2014/09/02/how-to-install-a-start-button/#more-49
thanks in advance if someone could help.
// (C) 2014 Scott Hubble. NOT FOR COMMERCIAL USE.
//Push button ignition switch for automobiles.
//Made for 1988-2000 Honda Civic/CRX, but may be adapted to other vehicles.
//By Scott Hubble. Original version started 2114 Aug. 11.
//Ver. 6 started 2014 Aug. 15. Completed 2014 Aug. 15 @ 23:10 -7 UTC.
//UPDATE: 2014 Aug. 16 - Added LED output for button illumination.
//UPDATE: 2014 OCT. 2 - Changed for standalone Atmega.
int b1 = 3; //Start button.
int b2 = 2; //Clutch interlock switch.
int acc = 9; //Accessory output.
int ign = 8; //Ignition output.
int st = 7; //Starter output.
int ledPin = 12; //LED for button illumination.
int accLed = 11; //ACC indicator.
int onLed = 13; //ON indicator.
long unsigned time = 0; // Timer.
long unsigned time2 = 0; //2nd timer.
int ledFlash = 0;
int ledFlash2 = 0;
int ledOn = 0;
int b1Stat = 0; //Was the primary switch pressed?
int b2Stat = 0; // Secondary switch pressed?
int did = 0;
int did2 = 0;
int did3 = 0;
int on = 0;
int on2 = 0;
pinMode(b1, INPUT);
pinMode(b2, INPUT);
pinMode(acc, OUTPUT);
pinMode(ign, OUTPUT);
pinMode(st, OUTPUT);
pinMode(ledPin, OUTPUT);
pinMode(accLed, OUTPUT);
pinMode(onLed, OUTPUT);
time = millis();
time2 = millis();
digitalWrite(acc, HIGH);
digitalWrite(ign, HIGH);
digitalWrite(st, HIGH);
digitalWrite(accLed, HIGH);
digitalWrite(onLed, HIGH);
digitalWrite(ledPin, HIGH);
// -------------------------Read the bottons:-----------
if(digitalRead(b1) == HIGH && b1Stat == 0){
b1Stat++;
on++;
delay(90);
if(digitalRead(b1) == LOW && b1Stat == 1){
b1Stat--;
on--;
delay(90);
if(digitalRead(b2) == HIGH && b2Stat == 0){
b2Stat++;
on2++;
delay(90);
if(digitalRead(b2) == LOW && b2Stat == 1){
b2Stat--;
on2--;
delay(90);
//--------------------Operation:---------------------------
if(on == 1 && on2 == 1 && did == 0){ // Start engine, IGN on.
digitalWrite(ign, LOW); //Write LOW to activate relay.
digitalWrite(st, LOW);
did = 1;
did2 = 0;
did3 = 1;
ledOn = 1;
if(on == 0 && did == 1){ //Starter off.
digitalWrite(onLed, LOW);
did = 2;
if(did == 2 && on == 0){ //ACC on after engine start.
digitalWrite(acc, LOW);
did = 3;
if(did == 3 && on == 1){ //Turn everything off.
did = 4;
ledOn = 0;
time2 = 0;
if(did == 4 && on == 0){
did = 0;
did2 = 0;
did3 = 0;
//-----------------NON STARTER OPERATION--------------------
if(on == 1 && did2 == 0 && did3 == 0){ //Push for ACC
digitalWrite(accLed, LOW);
did2 = 1;
ledOn = 1;
if(on == 0 && did2 == 1 && did3 == 0){
did2 = 2;
if(did2 == 2 && on == 1 && on2 == 0){ //IGN without start
did2 = 3;
if(on == 0 && did2 == 3 && did3 == 0){
did2 = 4;
if(did2 == 4 && on == 1 && on2 == 0){ //ALL SYSTEMS OFF.
did2 = 5;
ledOn = 0;
time2 = 0;
if(did2 == 5 && on == 0){
did2 = 0;
//-----------------LED OUTPUT/BUTTON FLASH/illum.-------------------
if(ledOn == 1 && time2 == 0){
digitalWrite(ledPin, LOW);
time2 = 1;
}else if(millis() - time > 5000 && ledOn == 0 && b2Stat == 0){
time = millis();
ledFlash = 1;
if(millis() - time > 100 && ledFlash == 1 && ledOn == 0 && b2Stat == 0){
time = millis();
ledFlash = 0;
if(b2Stat == 1 && b1Stat == 0 && ledOn == 0){
delay(50);
delay(60);
