Would love feedback on first solo code for project
This is my first Arduino project after reading about the Arduino world and getting hooked.
So my goal was to make a bath tub temperature alarm that would let me know when the water temp got down to the perfect temperature by sounding a small buzzer (that way I didn't have to sit there and keep testing with my foot :P). However, I found that because of the noise and jumpiness of the TC reading, I had to build in some kind of function so the the alarm didn't set until it stabilized under the set temperature. So I just set up a "time" variable that counted whenever the TC is under my set temp, but resets if it jumps back above.
I also build in a double buzz alarm to tell me if the water is below 110F, at which point I need to add more hot water.
Proud to say it works, but since I'm not the most experienced coder, I'd love to get some feedback on my code, as I'm sure there's a more eloquent way to achieve what I did.
Here's the code; any feedback is welcome.
Thanks so much.
New Arduinoid,
EJ1616
// code for bath water temperature alarm.
#include "max6675.h"
int tempset = 114; //temp alarm setpoint
int buzzer = 9; //buzzer pin
int time = 0; //beginning time
int thermoDO = 4; //these are for MAX6675
int thermoCS = 5;
int thermoCLK = 6;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
int vccPin = 3;
int gndPin = 2;
  // use Arduino pins
  pinMode(buzzer, OUTPUT);
  pinMode(vccPin, OUTPUT); digitalWrite(vccPin, HIGH);
  pinMode(gndPin, OUTPUT); digitalWrite(gndPin, LOW);
  // wait for MAX chip to stabilize
  // basic readout test, just print the current temp and time variable
   Serial.print("F = ");
   Serial.println(thermocouple.readFarenheit());
   Serial.print("Time = ");
   Serial.println(time);
//count how long time is below tempset
   if (thermocouple.readFarenheit() < tempset){
     time=time + 1;  // counts time after TC reaches tempset
   if (thermocouple.readFarenheit() > tempset){
      time = 0; //reset time
//turn on alarm if TC is under temp set for 30 seconds
  if (time > 30){
     digitalWrite(buzzer,HIGH);  //alarms buzzes on and off
     digitalWrite(buzzer, LOW);
// Turn on fast alarm if TC is below 110F
  if (thermocouple.readFarenheit() < 110){
     delay(300);
     delay(300);
     delay(300);
This should be
const int buzzer = 9; //buzzer pin
so you don't accidentally overwrite the value in buzzer. Also, I like to see the word pin appear in names of variables that hold pin numbers, like buzzerPin, just so I KNOW that the variable represents a pin number.
int gndPin = 2;
Can't tell from this name what this pin is for. If it is really for connecting something to ground, you really should connect it to ground, not to a pin that you pull LOW.
  if (time > 30){
One second is an annoying long time for a buzzer.
On each pass through loop(), you read the temperature 4 times. Wouldn't one be sufficient? In the few hundred nanoseconds that elapse between the 2 and 4th readings, is the temperature likely to change that much? If it is, I certainly wouldn't be getting in that water.
Here, for example, it seems like the if statement should be replaced by an else statement.
What should happen is the temperature equals tempset?
Now that this works, look at the blink without delay example, and learn how to get rid of all the delay()s.
Are you powering the MAX chip from IO pins?
If so it's a novel approach and should work as the chip only draws about 1mA but it's a little strange.
Rob
http://arduino.cc/playground/Main/RunningAverage
this is a running average library. You can use it to get a running average to smooth out the noise you see on your sensor.
PaulS - thanks, these are great pointers.
Graynomad & PaulS, as for using the MAX6675, I just used what I learned at Adafruit tutorial for thermocouples: Thermocouple sensor tutorial
liudr, love the RunningAverage!
I've incorporated most of everyone's suggestions and it's definitely running way better.
One thing though, Im using a "delay(1000)" because I want to read to the serial port (9600 baud rate). However, I think this delay is messing up my buzzer timing; meaning, it buzzes at 1second intervals rather than the 500milliseconds that I've set in the "interval" constant.
Any clues on how to keep the baud rate, but get my buzzer to buzz at the interval I want?
Thanks!
Code below:
//include Max6675 library
//include RunningAverage library
#include "RunningAverage.h"
//Constants won't change
const int tempset = 90; //temp alarm setpoint
const int buzzerPin = 9; //buzzer pin
const int thermoDO = 4; //these are for MAX6675
const int thermoCS = 5;
const int thermoCLK = 6;
const int vccPin = 3;
const int gndPin = 2;
//Variables will change:
int buzzerState = LOW;    //buzzerState used to set the buzzer
long previousMillis = 0;  // will store last time buzzer was updated
long interval = 500;    // interval at which to buzz buzzer (milliseconds) for primary alarm
RunningAverage myRA(20); //Running Average
int samples = 0;
  myRA.clr(); // explicitly start clean
  // use Arduino pins
  pinMode(buzzerPin, OUTPUT);
   myRA.add(thermocouple.readFarenheit());
   samples++;
   Serial.print("Running Average F = ");
   Serial.println(myRA.avg());
   if (samples == 300)
    samples = 0;
    myRA.clr();
//check average temp versus tempset and buzz alarm if so
   if (myRA.avg() < tempset){
      if(currentMillis - previousMillis > interval) {
        // save the last time buzzed buzzer
         // if the buzzer is off turn it on and vice-versa:
         if (buzzerState == LOW)
           buzzerState = HIGH;
            buzzerState = LOW;
      // set the buzzer with the buzzerState of the variable:
      digitalWrite(buzzerPin, buzzerState);
        buzzerState = LOW;
When posting code, please use the # icon in the editor's toolbar.
(You can go back over previous posts, click "modify", highlight the code, then click on the # icon, then click "save")
Not sure what you mean by this:
But that delay is your problem. If you were reading the serial port, the input would be buffered - you don't need to wait.
If you're thinking you need to pause to let the serial.prints you have complete, you don't. They block until all serial data has been sent.
In short, try it without the delay & see.
   if (samples == 300)
    samples = 0;
    myRA.clr();
You are setting up a buffer to hold twenty values, then clearing it after reading 300 values. Doesn't quite compute for me. The idea behind the class is that it maintains a running average, discarding the oldest value when the internal buffer gets full. Your intervention is not needed.
        buzzerState = LOW;
Good grief, can you shut the racket off? You set the new state for the buzzer when the average temperature drops below tempset, but you never actually apply it.
This value will be overwritten by an unsigned long value, which can be quite a bit larger than a signed long value, causing previousMillis to contain a negative number. This variable should be unsigned.
I guess this is signed to allow for negative intervals.
This doesn't make sense to me, either. There are no Serial.read() statements in your code.
If you are trying to prevent flooding the Serial Monitor with messages, a good idea, record when you last sent a value, and send again only after a suitable (unsigned) interval. Get rid of the delay().
PaulS, thanks so much. This has been very helpful. Most of those things I did (like the 300 sample clear out) was because that's what I found in tutorials and stuff, but thanks for pointing it out because I've learned a lot.
I did everything you said, but the temperature will no longer average. Obviously it's something to do with how I've set up recording when I send to Monitor, and then checking the interval of time when since last send to Monitor.
I've pasted here two sets of code. The first one "A" isn't averaging the temps any more and when I look at the serial Monitor, it shows the same temperature for every value. It never changes. The buzzer just buzzes at its interval, but the program isn't really monitoring my temperature any more
The second code "B" has the delay (which I'm trying to get rid of) in it and this one works fine; that is, it's averaging and displaying the changing temps on the Monitor and the buzzer is buzzing when it's supposed to.
I'm really stumped about how to get rid of that delay. I understand the Blind_without_delay principle and have applied to the buzzer, but why is it messing up the program now?
A
unsigned long previousMillis = 0;  // will store last time buzzer was updated
unsigned long previousMillis_Serial = 0;  // will store last time sent to Serial Monitor
unsigned long interval = 750;    // interval at which to buzz buzzer (milliseconds) for primary alarm
unsigned long interval_Serial = 1000;    // interval at which to send to Serial Monitor
  // use Arduino pins
   if(currentMillis - previousMillis_Serial > interval_Serial) {
      // save the last send to Serial
      previousMillis_Serial = currentMillis;
           buzzerState = HIGH;
            buzzerState = LOW;
        buzzerState = LOW;
B
unsigned long interval = 1000;    // interval at which to buzz buzzer (milliseconds) for primary alarm
  // use Arduino pins
//check agerage temp versus tempset and buzz alarm if so
           buzzerState = HIGH;
            buzzerState = LOW;
        buzzerState = LOW;
Since you don't print the individual readings, how do you know where the problem is? The problem could be that the thermocouple reading never changes. Or, it could be something with the way that the average is computed. You need to determine whether it is a hardware problem (the thermocouple) or a software problem (running average computation). Only then can you hope to fix it.
