i dont even know if this is the right place to post this thread... sorry if its off.
would this buzzer work on any of the Arduio Uno's?
http://www.eio.com/p-18045-velleman-tv1-piezo-transducer-5vac-40khz-85db-lead-type.aspx
Yes, I think it would.
Its not a "buzzer" - a buzzer takes DC power and contains an oscillator to drive the transducer. This is just the bare transducer - you drive it with a square/rectangular wave. Since its piezo DC offset doesn't matter so you can connect it to a PWM pin and ground and then analogWrite (pin, 128)
- should be able to hear something. It is loudest at resonance (4kHz) and PWM pins are either 500Hz or 1kHz by default (roughly).
For safety I'd add a 220 ohm resistor in series just in case to limit the current.
