WProgram.h and Arduino.h
Using Arduino 1.5.8 with Arduino Due
Trying to use tinyFAT and UTFT_tinyFAT
Windows 7 64bit
Example code I’m trying to run:
// Demo_Landscape (C)2013 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of the loadBitmap()-function.
// This program requires UTFT_tinyFAT, UTFT v2.41 or higher,
// as well as tinyFAT v3.0 or higher.
// The image files must be present in the root folder
// of a FAT16 formatted SDcard in the module cardslot.
// Please note that this demo only supports the following
// display sizes:
//      220x176
//      320x240
//      400x240
//      480x272
//      800x480
#include <tinyFAT.h>
#include <UTFT.h>
#include <UTFT_tinyFAT.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
UTFT         myGLCD(ITDB32S, 38, 39, 40, 41);   // Remember to change the model parameter to suit your display module!
UTFT_tinyFAT myFiles(&myGLCD);
// List of filenames for pictures to display.
char* files320[]={"PIC301.RAW", "PIC302.RAW", "PIC303.RAW", "PIC304.RAW", "PIC305.RAW", "PIC306.RAW", "PIC307.RAW", "PIC308.RAW", "PIC309.RAW", "PIC310.RAW"}; // 320x240
char* files400[]={"PIC401.RAW", "PIC402.RAW", "PIC403.RAW", "PIC404.RAW", "PIC405.RAW", "PIC406.RAW", "PIC407.RAW", "PIC408.RAW", "PIC409.RAW", "PIC410.RAW"}; // 400x240
char* files220[]={"PIC601.RAW", "PIC602.RAW", "PIC603.RAW", "PIC604.RAW", "PIC605.RAW", "PIC606.RAW", "PIC607.RAW", "PIC608.RAW", "PIC609.RAW", "PIC610.RAW"}; // 220x176
char* files480[]={"PIC701.RAW", "PIC702.RAW", "PIC703.RAW", "PIC704.RAW", "PIC705.RAW", "", "", "", "", ""}; // 480x272
char* files800[]={"PIC801.RAW", "PIC802.RAW", "PIC803.RAW", "PIC804.RAW", "PIC805.RAW", "", "", "", "", ""}; // 800x480
char* files[10];
int picsize_x, picsize_y;
boolean display_rendertime=false;  // Set this to true if you want the rendertime to be displayed after a picture is loaded
boolean display_filename=true;  // Set this to false to disable showing of filename
word res;
long sm, em;
  myGLCD.InitLCD();
  myGLCD.clrScr();
  file.initFAT();
  myGLCD.setColor(255,255,255);
  myGLCD.setFont(SmallFont);
  picsize_x=myGLCD.getDisplayXSize();
  picsize_y=myGLCD.getDisplayYSize();
  switch (picsize_x)
    case 220:
      for (int z=0; z<sizeof(files220)/sizeof(*files220);z++)
        files[z] = files220[z];
    case 320:
      for (int z=0; z<sizeof(files320)/sizeof(*files320);z++)
        files[z] = files320[z];
    case 400:
      for (int z=0; z<sizeof(files400)/sizeof(*files400);z++)
        files[z] = files400[z];
    case 480:
      for (int z=0; z<sizeof(files480)/sizeof(*files480);z++)
        files[z] = files480[z];
    case 800:
      for (int z=0; z<sizeof(files800)/sizeof(*files800);z++)
        files[z] = files800[z];
  for (int i=0; i<(sizeof(files)/sizeof(*files)); i++)
    if (files[i]!="")
      sm=millis();
      res=myFiles.loadBitmap(0, 0, picsize_x, picsize_y, files[i]);
      em=millis();
      if (res!=0)
        if (res==0x10)
          myGLCD.print("File not found...", 0, 0);
          myGLCD.print(files[i], 0, 14);
          myGLCD.print("ERROR: ", 0, 0);
          myGLCD.printNumI(res, 56, 0);
        delay(3000);
        myGLCD.clrScr();
        if (display_rendertime==true)
          myGLCD.print("Rendertime (secs):", 0, 0);
          myGLCD.printNumF(float((em-sm)/1000.0), 2, 160,0);
        if (display_filename==true)
          myGLCD.print(files[i], CENTER, myGLCD.getDisplayYSize()-12);
        delay(3000);
Error:
In file included from Demo_Landscape.ino:20:0:
C:\Users\alsipj\Documents\Arduino\libraries\tinyFAT/tinyFAT.h:39:23: fatal error: WProgram.h: No such file or directory
  #include "WProgram.h"
compilation terminated.
Error compiling.
I’ve seen a couple posts on this issue and the primary response is to go into the .h file and change WProgram. to Arduino.h. I used N++ to change the .h file and still get an error:
In file included from C:\Users\alsipj\Documents\Arduino\libraries\tinyFAT\mmc.cpp:1:0:
C:\Users\alsipj\Documents\Arduino\libraries\tinyFAT\mmc.h:25:23: fatal error: WProgram.h: No such file or directory
Error compiling.
I found the mmc.h file it referred to and changed it there as well and get this error:
C:\Users\alsipj\Documents\Arduino\libraries\tinyFAT\mmc.h:70:9: error: 'regtype' does not name a type
  static regtype *P_SS, *P_MISO, *P_MOSI, *P_SCK;
C:\Users\alsipj\Documents\Arduino\libraries\tinyFAT\mmc.h:71:9: error: 'regsize' does not name a type
  static regsize B_SS, B_MISO, B_MOSI, B_SCK;
etc...
Is this an issue on the Due? I noticed running Arduino 1.0.6 the program seemed to run fine, but it doesn’t support Due. Thank you in advance for any help!
It looks like the problem is compiler-related, not board-related.
You’ve got to search where those datatypes (regtype) come from
