wrap Nextion library into a class
First, if there is an overall better(easier) UI solution for an esp32 based board, I’m all ears.
I am trying to wrap the nextion library (https://github.com/itead/ITEADLIB_Arduino_Nextion/) into a class called Display.
I previously had this working without a class, in a simpler sketch. Now Im trying to port it over and have a couple small issues.
I whittled the class down to something postable. there were about 100 member functions, and they all do something very similar, just wanted to get to the point.
#ifndef __DISPLAY_TEST_H__
#define __DISPLAY_TEST_H__
#include <Nextion.h>
class Display_Test
private:
    NexRtc rtc;
    //Lock Page
    NexPage lockPage = NexPage(0, 0, "Lock");
    //Select Page
    NexPage selectPage = NexPage(1, 0, "Select");
    NexButton settingsButton = NexButton(1, 5, "bSettings");
//Settings Page
    NexPage settingsPage = NexPage(6, 0, "Settings");
    NexButton settingsSaveButton = NexButton(6, 1, "bSave");
    NexButton settingsCancelButton = NexButton(6, 2, "bCancel");
    NexTouch *nex_listen_list[7] = {
        &settingsPage,
        &selectPage,
        &lockPage,
        &settingsButton,
        &settingsSaveButton,
        &settingsCancelButton,
        NULL};
    void ButtonSettingRelease(void *);
    void ButtonSettingsSaveRelease(void *);
    void ButtonSettingsCancelRelease(void *);
public:
    Display_Test();
    void begin();
#endif /*__DISPLAY_TEST_H__*/
#include "display_test.h"
Display_Test::Display_Test()
void Display_Test::begin()
    Serial2.println("Setting up Display");
    nexInit();
    settingsButton.attachPop(ButtonSettingRelease, &settingsButton); //compiler error
    settingsSaveButton.attachPop(ButtonSettingsSaveRelease, &settingsSaveButton); //compiler error
    settingsCancelButton.attachPop(ButtonSettingsCancelRelease, &settingsCancelButton); //compiler error
void Display_Test::ButtonSettingRelease(void *ptr)
    settingsPage.show();
void Display_Test::ButtonSettingsSaveRelease(void *ptr)
void Display_Test::ButtonSettingsCancelRelease(void *ptr)
the compiler shows this:
src\display_test.cpp:10:67: error: invalid use of non-static member function
and this:
argument of type “void (Display_Test::*)(void *ptr)” is incompatible with parameter of type “NexTouchEventCb”
for each of the attachPop functions.
this works when not done within a class. Ive tried changing the 2nd variable to static and event const. im not sure what the right thing to do here is. -
A member function has a different type/signature than a global function.
The simple fix in your case is to make everything in your class "static". Note that it requires a bit more work to initialize those static classes.
something like this?:
class Display_Test
private:
    NexRtc rtc;
    //Lock Page
    static NexPage lockPage;
    //Select Page
    static NexPage selectPage;
    static NexButton settingsButton;
    //Settings Page
    static NexPage settingsPage;
    static NexButton settingsSaveButton;
    static NexButton settingsCancelButton;
        &settingsPage,
        &selectPage,
        &lockPage,
        &settingsButton,
        NULL};
    static void ButtonSettingRelease(void *);
    static void ButtonSettingsSaveRelease(void *);
    static void ButtonSettingsCancelRelease(void *);
    Display_Test() {}
public:
    void begin();
NexPage Display_Test::lockPage = NexPage(0, 0, "Lock");
NexPage Display_Test::selectPage = NexPage(1, 0, "Select");
NexButton Display_Test::settingsButton = NexButton(1, 5, "bSettings");
NexPage Display_Test::settingsPage = NexPage(6, 0, "Settings");
NexButton Display_Test::settingsSaveButton = NexButton(6, 1, "bSave");
NexButton Display_Test::settingsCancelButton = NexButton(6, 2, "bCancel");
    nexInit();
assuming that the above is correct, I have a second part...
Let's say that I have a bunch of different classes. Heater, Sensor, WiFi, AWS_IOT, etc.
They all need to write to the display class, what structure would be best to do this efficiently?
I think that doing something like this is wrong:
Heater heater();
int currentTemp = heater.getCurrentTemp();
Display::updatePage2Temp(currentTemp); //static
and something like this might not be right either:
class Heater(){
  int Heater::getCurrentTemp(){
    //gets the temp from the sensor
  void Heater::updateDisplay(int currentTemp){
I would like everything to use the Display, and the Display having a known state (what page it is on)
Then, it's time to learn in deep: https://isocpp.org/wiki/faq/pointers-to-members.
if I'm not back in 24 hours.... I've died.
tell my family I love them.
ok, i read that whole page. I feel as though I was lacking context though.
why would I use a pointer to a member?
I tried my hand at getting this to work and would like feedback if this is the correct way. Since my display class is so large, I just uploaded it to github
https://github.com/hicotton02/BeverageController
I made the display a singleton class. there will only ever be one and only one display, and the ESP32 is dual core, so it seems right.
in the heater class, I reference the display and during the Heater::taskThread() function, I call display->updateHtlTemp(temp);
and I assume in the sensors class, and any other class, I can do the same thing. Is this a supported/correct approach?
Theskaz,
I can't help with wrapping the Nextion libraries into a class, but are you aware that the ITEAD versions are full of bugs? I suggest you use instead Ray Livingston's versions of the Nextion libraries Ray has fixed many of the bugs.
I am actually, I have copied his files before. My nexconfig is a little different. thanks for pointing that out though!
theskaz:
If it works for you then don’t change it.
The C++ way to handle callback function is using the std::function<> container. But this container has overhead that may not be fit for microcontroller. However as far as I know, ESP does use this a lot to wrap their callback functions.
