Write accelerometer data by a webpage
Hello Everyone,
I use a Node MCU / SD Card Reader-Writer / Accelerometer LIS3DH.
I have a problem because I can turn on or turn of the sensor by the webpage, but when I want to write the the data on the SD card by the webpage button...It writes always the same values.
Here my code :
#include <ESP8266WiFi.h>
#include <Wire.h>
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
// Used for software SPI
#define LIS3DH_CLK 13
#define LIS3DH_MISO 12
#define LIS3DH_MOSI 11
// Used for hardware & software SPI
#define LIS3DH_CS 10
Adafruit_LIS3DH lis = Adafruit_LIS3DH();
#include <SPI.h>
#include <SD.h>
const char* ssid = "-------";
const char* password = "--------";
int T;
int ledPin = 13; // GPIO13
WiFiServer server(80);
File myFile;
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  // Connect to WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
  server.begin();
  Serial.println("Server started");
  // Print the IP address
  Serial.print("Use this URL to connect: ");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.println("/");
#ifndef ESP8266
  while (!Serial);     // will pause Zero, Leonardo, etc until serial console opens
#endif
    Serial.println("LIS3DH test!");
  if (! lis.begin(0x18)) {   // change this to 0x19 for alternative i2c address
    Serial.println("Couldnt start");
    while (1);
  Serial.println("LIS3DH found!");
  lis.setRange(LIS3DH_RANGE_4_G);   // 2, 4, 8 or 16 G!
  Serial.print("Range = "); Serial.print(2 << lis.getRange());
  Serial.println("G");
    if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  // Read the first line of the request
  String request = client.readStringUntil('\r');
  Serial.println(request);
  client.flush();
  // Match the request
  int value = LOW;
 if (request.indexOf("/LED=ON") != -1)  {
  myFile = SD.open("test.txt", FILE_WRITE);
  Serial.print("Writing to test.txt...");
  for (int t =0 ; t<5000 ; t++ ){
  sensors_event_t event;
  lis.getEvent(&event);
  myFile.print("\t\tX: "); myFile.print(event.acceleration.x);
  myFile.print(" \tY: "); myFile.print(event.acceleration.y);
  myFile.print(" \tZ: "); myFile.print(event.acceleration.z);
  myFile.println(" m/s^2 ");
    value = HIGH;
    t=t+1;
    delay(1);
 myFile.flush();
   myFile.close();
    while (request.indexOf("/LED=OFF") != -1)  {
    value = LOW;
  if (request.indexOf("/LED=OFF") != -1)  {
    value = LOW;
// Set ledPin according to the request
//digitalWrite(ledPin, value);
  // Return the response
  client.println("Content-Type: text/html");
  client.println(""); //  do not forget this one
  client.println("<!DOCTYPE HTML>");
  client.println("<html>");
  client.println("<h1 style=text-align:center;font-size:300%;color:blue;font-family:britannic bold;>North Sails</h1>");
  client.println("<TEXTAREA name="" rows=4 cols=8>Time (seconds)</TEXTAREA>");
  client.println("<a href=\"\"\"><button>Send </button></a>");
  client.println("
  client.print("Accelerometer is now: ");
  if(value == LOW) {
    client.print("Off");
  client.println("
  client.println("<a href=\"/LED=ON\"\"><button>Turn On </button></a>");
  client.println("<a href=\"/LED=OFF\"\"><button>Turn Off </button></a>");
  client.println("</html>");
  Serial.println("Client disonnected");
  Serial.println("");
Thank you for your help!
U.D
      value = LOW;
This code looks equivalent to an if() statement. It's also inside a block that already tested that LED-ON, so it is never going to be true unless you wanted to turn it on and off in the same HTTP request.
Use the auto-format to get your indenting correct. Your code will be easier to read.
Does the code work to log to the SD card without the HTTP request? Try to trim it down the smallest possible example which shows the error. Usually that will demonstrate to you where the error is.
