WRITE ADXL345 DATA TO SD CARD MODULE
Hi
I want to write my adxl xyz data to sd card module. i have made the code but herei want to add date and time. in the sd card file along with xyz i want date and time to write.
Can someone please help me.
#include <SD.h> //Load SD card library
#include<SPI.h> //Load SPI Library
#include "Wire.h"    // imports the wire library for talking over I2C
int ADXL345 = 0x53; // The ADXL345 sensor I2C address
float X_out, Y_out, Z_out;  // Outputs
int chipSelect = 4; //chipSelect pin for the SD card Reader
File AngleData; //Data object you will write your sesnor data to
void setup(){
Serial.begin(9600); //turn on serial monitor
//mySensor.begin();   //initialize pressure sensor mySensor
Wire.begin(); // Initiate the Wire library
  // Set ADXL345 in measuring mode
  Wire.beginTransmission(ADXL345); // Start communicating with the device
  Wire.write(0x2D); // Access/ talk to POWER_CTL Register - 0x2D
  // Enable measurement
  Wire.write(8); // (8dec -> 0000 1000 binary) Bit D3 High for measuring enable
  Wire.endTransmission();
  delay(10);
pinMode(10, OUTPUT); //Must declare 10 an output and reserve it
SD.begin(4); //Initialize the SD card reader
  Wire.write(0x32);
  Wire.endTransmission(false);
  Wire.requestFrom(ADXL345, 6, true); // Read 6 registers total, each axis value is stored in 2 registers
  X_out = ( Wire.read()| Wire.read() << 8); // X-axis value
  X_out = X_out; //For a range of +-2g, we need to divide the raw values by 256, according to the datasheet
  Y_out = ( Wire.read()| Wire.read() << 8); // Y-axis value
  Y_out = Y_out;
  Z_out = ( Wire.read()| Wire.read() << 8); // Z-axis value
  Z_out = Z_out/256;
AngleData = SD.open("PTData.txt", FILE_WRITE);
if (AngleData) {
Serial.print("X= ");
  Serial.print(X_out);
  Serial.print("   Y= ");
  Serial.print(Y_out);
  Serial.print("   Z= ");
  Serial.println(Z_out);
delay(250); //Pause between readings.
AngleData.print(X_out);
AngleData.print(",");
AngleData.println(Y_out);
AngleData.println(Z_out);
AngleData.close();                                  //close the file
You need a Real Time Clock (RTC) module. These are often based on ds1307 or ds3231 chips and have a coin cell for battery backup.
Your readings are every 250ms? Do you need time to be recorded to that precision, or is it ok if 4 readings have the same time with a precision of 1s?
PaulRB:
i want to read data every 4 seconds.
With the code which i have posted it is not saving to sd card
bmg1234:
Why are you asking for help writing the date and time to the card, when your code does not write anything to the card?
I want to do it together.
Can you please check the code. i took temperature code and made modification.
It is not writing anything to sd card
Code is working it is writing data to sd card.
Now i want to add date and time.
is there any possibilities to do without RTC?
You can have the user set a time and date and update that when the Arduino clock drifts. Use a time library to find out what day it is based on the last set date plus milliseconds since. It'd be a pain to code and run, get or build an Arduino with a crystal instead of resonator just to not have to reset often. Even with RTC you have to set the date/time at least once and need the library(s).
How it can be done? is there any example?
bmg1234:
bmg1234:
Is there an intermittent fault? Did you change or fix something?
PaulRB:
MISO and MOSI pins were connected wrong and i changed delay (250 ) to delay (4000).
Now i want to add time. can you please help me
bmg1234:
It is difficult for beginners and not convenient to use. Get an RTC.
PaulRB:
How can rtc be used with ADXL345.
if you have any example can you please send me
bmg1234:
Do you mean because they both need to connect to A4 & A5?
A4 & A5 are the i2c bus and many devices can be connected at the same time. Each device has a different address on the bus. The address of your ADXL345 is 0x53. The RTC will have a different address.
Hi
I bought DS3231 RTC.
Can you please explain me how the connections ti be made. ADXL sensor SDA and SCL Pins are connected to A4 and A5 of arduino. how to i connect RTC device now.
What changes i should make with the code
The RTC will also have SDA and SCL pins. Connect them to A4 & A5 also. Then follow this tutorial to test your RTC is working and set the time.
I Have made the code both date time and adxl value is writing to sd card but date and time is wrong.
How to set present time and date
#include <SD.h>
#include <SPI.h>
#include <DS3231.h>
File sdcard_file;
DS3231  rtc(SDA, SCL);
float output;
  pinMode(4, OUTPUT);
  delay(10);
  rtc.begin();
  //rtc.adjust(DateTime(F(__DATE__),F(__TIME__)));
  rtc.adjust(DateTime(2019, 7, 15, 20, 3, 0));
  // SD Card Initialization
  if (SD.begin(4))
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
  Wire.write(0x32); // Start with register 0x32 (ACCEL_XOUT_H)
  Y_out = Y_out;
  Z_out = Z_out/256;
  //Serial.print("The angle is: ");
if (AngleData) {
  Serial.print(rtc.getDateStr());
  Serial.print("     ");
  Serial.print(rtc.getTimeStr());
delay(4000); //Pause between readings.
AngleData.print(rtc.getDateStr());
   AngleData.print("     ");
    AngleData.print(rtc.getTimeStr());
AngleData.print("X= ");
AngleData.print(X_out);                             //write temperature data to card
AngleData.print("Y= ");//write a commma
AngleData.print(Y_out);                        //write pressure and end the line (println)
AngleData.print("Z= ");//write a commma
AngleData.close();
20:15:30.605 -> 1.2000 00:24:38The angle is: X= 60.00 Y= 179.00 Z= 0.57
20:15:30.605 -> 00:24:34The angle is: X= 62.00 Y= 182.00 Z= 0.56
20:15:30.605 -> 01.01.2000 00:24:38The angle is: X= 60.00 Y= 179.00 Z= 0.57
20:15:30.605 -> SD card is ready to use.
20:15:30.641 -> 01.01.2000 00:24:43The angle is: X= 60.00 Y= 181.00 Z= 0.56
20:15:34.655 -> 01.01.2000 00:24:47The angle is: X= 59.00 Y= 181.00 Z= 0.57
20:15:38.687 -> 01.01.2000 00:24:51The angle is: X= 56.00 Y= 180.00 Z= 0.57
Did you follow the tutorial I posted a link to? That tutorial included setting the date/time.
This line:
should have set the correct time. Does your RTC have a coin cell fitted? Is there a piece of plastic that must be removed for the battery to connect?
