Write and load NeoPixel color setting to/from EEPROM
TL;DR: please help me figuring out how I can save and load the color setting to/from EEPROM.
Hello, I'm working on my first Arduino/NeoPixel project (with the help of a lot of lending from scripts I found on the internet). Basically a led strip with all leds showing the same color with manual input for color and brightness adjustment.
The color selection is controlled using a rotary encoder knob which cycles through "colorWheel" in the sketch. The brightness is controlled using pushbuttons which make it go up or down in mode/case with a certain brightness setting attached to it.
So far everything is working as it should, however I want it to remember it's last color and brightness setting when the strip is powered off. As soon as power is restored it should resume with the same color and brightness setting.
I finally managed to make this so for the brightness setting: each time I press the brightness buttons it will write the mode to EEPROM (EEPROM.put). When the Arduino is powered on after power loss it will read the EEPROM (EEPROM.get) and display the leds with the last brightness setting.
I'm also trying to do the same for the color setting (which are generated with uint32_t colorWheel), to make the leds light up when powering on with the rgb values from the last selection, but whatever I'm trying (and I've tried a lot), it's not working...
Could anyone help me out with suggestions? Thank you!
#include <Encoder.h>
#include <EEPROM.h>
const int NUM_LEDS = 28;
const int LED_PIN = 5;
const int BRIGHTNESS = 255;
const int WHEEL_SIZE = 256;
const int ENCODER_PIN_1 = 2;
const int ENCODER_PIN_2 = 3;
const int BUTTON_1 = 13;
const int BUTTON_2 = 12;
const int BUTTON_3 = 8;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, LED_PIN, NEO_RGB + NEO_KHZ800);
Encoder encoder(ENCODER_PIN_1, ENCODER_PIN_2);
int mode = 0;
long lastPush = 0;
int autoPosition = 0;
  pinMode(13, INPUT);
  digitalWrite(13, HIGH);
  pinMode(12, INPUT);
  digitalWrite(12, HIGH);
  pinMode(8, INPUT);
  digitalWrite(8, HIGH);
  strip.begin();
long normalize(long value, long radix) {
  long rval = value % radix;
  if (rval < 0) return radix + rval;
  else return rval;
  EEPROM.get(0, mode);
  if (mode > 9) {
    mode = 5;
    EEPROM.put(0, 0);
  int button1 = digitalRead(BUTTON_1);
  if (button1 == 0) {
    if ((millis() - lastPush) > 250) {
      lastPush = millis();
      mode++;
      if (mode > 9) mode = 9;
      EEPROM.put(0, mode); // store the chose effect
  int button2 = digitalRead(BUTTON_2);
  if (button2 == 0) {
      mode--;
      if (mode < 1) mode = 1;
      asm volatile ("  jmp 0");      // reset the Arduino
  int button3 = digitalRead(BUTTON_3);
  if (button3 == 0) {
      if (mode < 1) mode = 5;
      else mode = 0;
  long knobValue = encoder.read() / 2;
  long ledPosition = normalize(knobValue, NUM_LEDS);
  long colorValue = normalize(knobValue * 5, WHEEL_SIZE);
  long sleepValue = abs(knobValue) % 500;
  switch (mode) {
    case 1:
    for (int i = 0; i < NUM_LEDS; i++) {
        strip.setBrightness(255);
        strip.setPixelColor(i, colorWheel(BRIGHTNESS, colorValue));
    case 2:
        strip.setBrightness(200);
    case 3:
        strip.setBrightness(150);
    case 4:
        strip.setBrightness(100);
    case 5: for (int i = 0; i < NUM_LEDS; i++) {
        strip.setBrightness(70);
    case 6:
        strip.setBrightness(50);
    case 7:
        strip.setBrightness(35);
    case 8:
        strip.setBrightness(20);
    case 9:
        strip.setBrightness(00);
  strip.show();
// given a wheel position in 0-255 range
// return a rainbow color adjusted by intensity 0 to 1.0
uint32_t colorWheel(float intensity, byte wheelPos)
  const int WHEEL_THIRD = (WHEEL_SIZE - 1) / 3;
  if (intensity < 0.0 ) intensity = 0.0;
  if (intensity > 1.0) intensity = 1.0;
  // as wheelPos progresses from 0 to 255 once, colorIndex should progress from 0 to 255 3 times
  // find out position in current third of wheel then multiple by 3 to get full color value
  byte colorIndex = (wheelPos % WHEEL_THIRD) * 3;
  int fadeColor = (255 - colorIndex) * intensity;  // color going down
  int increaseColor = colorIndex * intensity;    // color going up
  switch (wheelPos / WHEEL_THIRD) {
    case 0:    // first third of the wheel, red fading, no green, blue increasing
      return Adafruit_NeoPixel::Color(fadeColor, 0, increaseColor);
      EEPROM.put(5, Adafruit_NeoPixel::Color); // store the chose effect
    case 1:    // second third of the wheel no red, green increasing, blue fading
      return Adafruit_NeoPixel::Color(0, increaseColor, fadeColor);
    case 2:    // last third of the wheel, red increasing, green fading, no blue
      return Adafruit_NeoPixel::Color(increaseColor, fadeColor, 0);
You should only read from the EEPROM in your setup function. There is no point in calling EEPROM.get() on every loop. Just store the mode in the mode variable.
Dutch_Guy:
EEPROM.put() will never be called in this code because the return statement comes before it.
pert:
Thanks for the advice.
You're welcome. I'm glad if I was able to be of assistance. Enjoy!
Per
