Write C in Win 10
Hi
Is anyone here programming on a win 10 computer? If so, any suggestions for environment to setup etc?
@liquidfuzz
Your topic was Moved to it's current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
liquidfuzz:
Hi
Are you asking about writing code for the Arduino or to run on the PC ?
i use cygwin on Windows to provide a Unix/Linux environment
Sorry if my first post was vague...
Currently I use the gcc compiler (with an editor called sublime). I would like to try some editor with built in compiler functionality.
Still vague
Are you writing Arduino code or PC code ?
I'm not aware of any IDE short of maybe something like VisualC++ that uses an in-built compiler/linker.
I use Code::Blocks 20.03 IDE on my Win10 machine but it still uses GNU GCC.
unix is the programming environment (i.e. IDE)
i often have one window open to edit code and a 2nd repeatedly running make rebuilding and re-running if it gets that far.
