Write command on shell automatically using sketch for ARDUINO YUN
Goodmorning everyone,
I'm implementing the lwm2m client on arduino yun based on this project:
my problem is that after having correctly established the connection with the server I cannot change the values ​​related to the sensors. the code is as follows:
 Process p;
  int temp = 0;
 SerialUSB.begin(9600);
 while (!SerialUSB);
 SerialUSB.println("Init  bridge lib...\n");
 Bridge.begin();
 String conn = "/root/./lwm2mclient -h leshan.eclipse.org -n arduino_yun_client -4";
  p.runShellCommandAsynchronously(conn);
  temp = 0;
     Serial.println(temp);
   changeResource("/1024/0/10", temp);
     delay(1500);
 void changeResource(String resource, int value){
    String conn = "change "+resource+" "+value;
  p.println(conn);
  p.flush();
n particular, the changeResource method is not executed, which allows the values ​​related to the sensors to be changed. Or rather, the method is executed but actually p.println (conn) and p.flush () do not send any commands.
N.B. running the client (./lwm2mclient -h leshan.eclipse.org -n arduino_yun_client -4) and then entering the command change / 1024/0/10 5
from arduino, through ssh it works perfectly.
