write(const uint8_t *buf, size_t size) from SD
I am trying to write a struct to a file on an SD card.
this is the struct:
struct record {
   time_t time;
   unsigned int    p1023;
   unsigned int    t1023;
} rec;
and to write it, I thought to use the write function of SD, in this case the file instance is "logfile" :
   logfile.write(rec,sizeof(rec));
but I get "no matching function for call to 'File::write(record&,unsigned int);
I understand it's a type issue, I tried modifiers and pointers, but it doesn't want to work, any help?
with kind regards,
Carlos
Without seeing the function prototype for write, try:
logfile.write(&rec,sizeof(rec));
(edit)
or:
logfile.write((byte *) &rec,sizeof(rec));
Thanks Nick, the 2nd one did it.
