Dear experts,
My goal is to capture a picture with an ESP32-CAM and save it via UART (HardawareSerial1) to a CH376 module, on a USB flashdrive.
Using Scott C example, I can write a String-based file without issue, but I need guidance for saving a small RAW image file.
Please find below the code employed in an attempt of saving a picture by entering "A" on the serial terminal. The trouble shall be located around line 126, with the image buffer written over serial. My output files remains desperately 1 Byte big only...
#include "esp_camera.h"
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include <HardwareSerial.h>
HardwareSerial USB(1);
byte computerByte; //used to store data coming from the computer
byte USB_Byte; //used to store data coming from the USB stick
int timeOut = 3000; //TimeOut is 3 seconds. This is the amount of time you wish to wait for a response from the CH376S module.
int LED = 33; //the red LED is connected to digital pin 33
const int RST = 2; // Add a reset line or the chip won't connect
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
pinMode(RST, OUTPUT);
digitalWrite(RST, HIGH);
delay(100);
digitalWrite(RST, LOW);
Serial.begin(2000000); // Setup serial communication with the CH376S module (using the default baud rate of 9600)
USB.begin(57600, SERIAL_8N1, 12, 13); //, Comm_Txd_pin, Comm_Rxd_pin); // Define and start Comm serial port
delay(100);
Serial.println("Serial started...");
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_GRAYSCALE;
if (psramFound()) {
config.frame_size = FRAMESIZE_QQVGA; // candidates are QQVGA|QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
config.fb_count = 1;
Serial.println(F("PSRAM NOT FOUND"));
return;
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("CAMERA ERROR 0x%x", err);
return;
Serial.println("Setting to USB mode...");
set_USB_Mode(0x06);
if (Serial.available()) {
computerByte = Serial.read(); //read any incoming bytes from the Serial monitor, and store this byte in the variable called computerByte
if (computerByte == 65) { //A CAPITAL
Serial.println("Let's take and save a picture");
takePicture();
if (USB.available()) { // This is here to capture any unexpected data transmitted by the CH376S module
Serial.print("CH376S has just sent this code:");
Serial.println(USB.read(), HEX);
//END OF LOOP FUNCTION ========================================================================================================================================
// Take a picture and save the buffer to USB drive
void takePicture() {
camera_fb_t * fb = NULL;
Serial.print("1 SEC TO PHOTO");
fb = esp_camera_fb_get();
if (!fb) {
Serial.print("ERROR WHILE TAKING PHOTO");
return;
set_USB_Mode(0x06); //Set to USB Mode
USBdiskMount(); //Prepare the USB for reading/writing - you need to mount the USB disk for proper read/write operations.
setFileName("PIC.BMP"); //Set File name
if (fileCreate()) { //Try to create a new file. If file creation is successful
uint16_t dataLength = fb->len; // This variable holds the length of the data to be written (in bytes)
Serial.print("Data Length:");
Serial.println(dataLength);
delay(100);
// This set of commands tells the CH376S module how many bytes to expect from the Arduino. (defined by the "dataLength" variable)
USB.write(0x57);
USB.write(0xAB);
USB.write(0x3C);
USB.write((byte) dataLength);
USB.write((byte) 0x00);
Serial.println("Data length written to FILE");
if (waitForResponse("setting data Length")) { // Wait for an acknowledgement from the CH376S module before trying to send data to it
Serial.println("Waiting for acknoledgment from CH376...");
if (getResponseFromUSB() == 0x1E) { // 0x1E indicates that the USB device is in write mode.
USB.write(0x57);
USB.write(0xAB);
USB.write(0x2D);
Serial.println("CH376S in write mode...");
for (size_t i = 0; i < fb->len; i++)
if (i % 16 == 0) USB.printf("\n%06u\t", i);
if (fb->buf[i] < 0x10) USB.write('0');
Serial.println(fb->buf[i], HEX);
USB.print(fb->buf[i], HEX);
if (waitForResponse("writing data to file")) { // wait for an acknowledgement from the CH376S module
Serial.print("Write code (normally FF and 14): ");
Serial.print(USB.read(), HEX); // code is normally 0xFF
Serial.print(",");
USB.write(0x57);
USB.write(0xAB);
USB.write(0x3D); // This is used to update the file size. Not sure if this is necessary for successful writing.
if (waitForResponse("updating file size")) { // wait for an acknowledgement from the CH376S module
Serial.println(USB.read(), HEX); //code is normally 0x14
else {
Serial.println("File could not be created, or it already exists");
fileClose(0x01);
esp_camera_fb_return(fb);
//fileCreate()========================================================================================
//the command sequence to create a file
boolean fileCreate() {
boolean createdFile = false;
USB.write(0x57);
USB.write(0xAB);
USB.write(0x34);
if (waitForResponse("creating file")) { //wait for a response from the CH376S. If file has been created successfully, it will return true.
if (getResponseFromUSB() == 0x14) { //CH376S will send 0x14 if this command was successful
createdFile = true;
return (createdFile);
//set_USB_Mode=====================================================================================
//Make sure that the USB is inserted when using 0x06 as the value in this specific code sequence
void set_USB_Mode (byte value) {
USB.write(0x57);
USB.write(0xAB);
USB.write(0x15);
USB.write(value);
delay(20);
USB_Byte = USB.read();
//Check to see if the command has been successfully transmitted and acknowledged.
if (USB_Byte == 0x51) { // If true - the CH376S has acknowledged the command.
Serial.println("set_USB_Mode command acknowledged"); //The CH376S will now check and monitor the USB port
//Check to see if the USB stick is connected or not.
if (USB_Byte == 0x15) { // If true - there is a USB stick connected
Serial.println("USB is present");
blinkLED(); // If the process was successful, then turn the LED on for 1 second
Serial.print("USB Not present. Error code:"); // If the USB is not connected - it should return an Error code = FFH
Serial.print(USB_Byte, HEX);
Serial.println("H");
Serial.print("CH3765 error! Error code:");
delay(20);
//USBdiskMount========================================================================================
//initialise the USB disk and check that it is ready - this process is required if you want to find the manufacturing information of the USB disk
void USBdiskMount() {
Serial.println("Mounting USB disk");
USB.write(0x57);
USB.write(0xAB);
USB.write(0x31);
if (waitForResponse("mounting USB disk")) { //wait for a response from the CH376S. If CH376S responds, it will be true. If it times out, it will be false.
Serial.println(">USB Mounted - OK");
Serial.print(">Failed to Mount USB disk.");
//setFileName======================================================================================
//This sets the name of the file to work with
void setFileName(String fileName) {
Serial.print("Setting filename to:");
Serial.println(fileName);
USB.write(0x57);
USB.write(0xAB);
USB.write(0x2F);
USB.write(0x2F); // Every filename must have this byte to indicate the start of the file name.
USB.print(fileName); // "fileName" is a variable that holds the name of the file. eg. TEST.TXT
USB.write((byte)0x00); // you need to cast as a byte - otherwise it will not compile. The null byte indicates the end of the file name.
delay(20);
//fileClose=======================================================================================
//closes the file
void fileClose(byte closeCmd) {
Serial.println("Closing file:");
USB.write(0x57);
USB.write(0xAB);
USB.write(0x36);
USB.write((byte)closeCmd); // closeCmd = 0x00 = close without updating file Size, 0x01 = close and update file Size
if (waitForResponse("closing file")) { // wait for a response from the CH376S.
byte resp = getResponseFromUSB();
if (resp == 0x14) { // CH376S will send 0x14 if this command was successful
Serial.println(">File closed successfully.");
Serial.print(">Failed to close file. Error code:");
Serial.println(resp, HEX);
//waitForResponse===================================================================================
//is used to wait for a response from USB. Returns true when bytes become available, false if it times out.
boolean waitForResponse(String errorMsg) {
boolean bytesAvailable = true;
int counter = 0;
while (!USB.available()) { //wait for CH376S to verify command
delay(1);
counter++;
if (counter > timeOut) {
Serial.print("TimeOut waiting for response: Error while: ");
Serial.println(errorMsg);
bytesAvailable = false;
delay(1);
return (bytesAvailable);
//getResponseFromUSB================================================================================
//is used to get any error codes or messages from the CH376S module (in response to certain commands)
byte getResponseFromUSB() {
byte response = byte(0x00);
response = USB.read();
Serial.println("Response from USB: \t");
Serial.print(response);
return (response);
//blinkLED==========================================================================================
//Turn an LED on for 1 second
void blinkLED() {
digitalWrite(LED, HIGH);
digitalWrite(LED, LOW);
This piece of code was written after the one from tolgaeng
Please note image structure fb is made of:
typedef struct {
uint8_t * buf; // Pointer to the pixel data
size_t len; // Length of the buffer in bytes
size_t width; // Width of the buffer in pixels
size_t height; // Height of the buffer in pixels
pixformat_t format; // Format of the pixel data
} camera_fb_t;
For future searches, note the RESET PIN of CH376 HAS to be triggered at startup.
Thank you for your help.
Simple_Jack
