hi guys.
i want to get a name from serial monitor and then replace it instead "HELLO WORLD" on Eleventh line. Actually in this code we write The considered word to tags. but i want to write a word that we write it from serial monitor. at line 11 i need help.
pls help if u can.
Eleventh line in code:
byte myData[16] = {" HELLO WORLD "}; // i want to get a name from serial monitor and save it instead "HELLO WORLD";
#include <SPI.h>
#include <MFRC522.h>
#define CSPin 53
#define ResetPin 5
MFRC522 RFIDmodule(CSPin, ResetPin);
MFRC522::MIFARE_Key key;
int blockNumber = 61;
byte myData[16] = {" HELLO WORLD "}; // i want to get a name from serial monitor and save it instead "HELLO WORLD"; HOW? PLS.
byte empty[16] = {0, 0 , 0 , 0 , 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
byte writtenData[18];
int writeBlock(int blockNumber, byte dataAddress[])
int largestModulo4Number = blockNumber / 4 * 4;
int trailerBlock = largestModulo4Number + 3;
if (blockNumber > 2 && (blockNumber + 1) % 4 == 0)
Serial.print(blockNumber);
Serial.println(" is a trailer block number:");
return 2;
Serial.println(" is a data block number:");
byte status = RFIDmodule.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &key, &(RFIDmodule.uid));
if (status != MFRC522::STATUS_OK)
Serial.print("PCD_Authenticate() failed: ");
Serial.println(RFIDmodule.GetStatusCodeName(status));
return 3;
status = RFIDmodule.MIFARE_Write(blockNumber, dataAddress, 16);
Serial.print("MIFARE_Write() failed: ");
return 4;
Serial.println("Data was written to selected block");
int readBlock(int blockNumber, byte dataAddress[])
Serial.print("PCD_Authenticate() failed (read): ");
return 3;
byte buffersize = 18;
status = RFIDmodule.MIFARE_Read(blockNumber, dataAddress, &buffersize);
Serial.print("MIFARE_read() failed: ");
return 4;
Serial.println("Data was successfully read");
SPI.begin();
RFIDmodule.PCD_Init();
Serial.println("Approximate your RFID tag...");
for (byte i = 0; i < 6; i++)
key.keyByte[i] = 0xFF;
if (!RFIDmodule.PICC_IsNewCardPresent())
return;
if (!RFIDmodule.PICC_ReadCardSerial())
return;
Serial.println("Found a tag");
writeBlock(blockNumber, myData);
readBlock(blockNumber, writtenData);
Serial.print("Your written data is: ");
Serial.println(String((char*)writtenData));
Serial.println("");
