Write / read from EEPROM not output correct values
rookie
I am currently trying to make a program to write the data from a sensor to the EEPROM as I cannot have my computer near (water based environment). I am also trying to keep the data as int's for greater data accuracy/ range. therefore i have split the int into bytes (or attempted to). I tested the output through the serial monitor and i was getting a varying out put which was good, so hopefully these were all being written to the EEPROM.
The read program would only giving me a repeating value when viewed through the serial monitor. (frustrating).
Help would be greatly appreciated. There is probably something super obvious that I'm missing.
Write code:
#include <EEPROM.h>
int MuscleSensorPin = A1;
int p_address  = 0;  //what does this do???
int p_value;
 void EEPROMWriteInt(int p_address, int p_value)
  p_value = analogRead (MuscleSensorPin);
  Serial.println(p_value);
  byte lowByte = ((p_value >> 0) & 0xFF);
  byte highByte = ((p_value >> 8) & 0xFF);
  EEPROM.write(p_address, lowByte);
  EEPROM.write(p_address + 1, highByte);
  p_address=( p_address + 1);
  delay(4000);
  EEPROMWriteInt(0 , p_value);
  delay(250);
Read CODE:
#include <EEPROM.h>
int p_address = 0;
byte value;
unsigned int EEPROMReadInt(int p_address)
     byte lowByte = EEPROM.read(p_address);
     byte highByte = EEPROM.read(p_address + 1);
     return ((lowByte << 0) & 0xFF) + ((highByte << 8) & 0xFF00);
     delay (500);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
Serial.println (EEPROMReadInt(p_address));
The last two lines of below will never be executed
     delay (500);
What is the range of your analog input signal?
What is the voltage (1.1V Internal, External AREF or 5V) for the VREF-point of the ADC?
Are you using Arduino NANO/UNO/MEGA/DUE?
These information are needed at our ends to do some experiments for helping you with some results.
