I'm trying to use the playground's tutorial to write data to an external eeprom...an AT24C1024BW. I'm using a mega1280 with a bootloader on a non-arduino clone board.
The eeproms A1,A2,A3 were left floating as was the wp pin since the datasheet said that the internal pullups would pull them to ground.
I'm using 0x50 for the eeprom's address and sending the data from Processing....
If I leave out the call to saving bytes to the eeprom all goes well. When I send the data to the eeprom every thing stops. I've put a flash routine in the mega to show when bytes were written. It never flashes. I've put print statements in Processing to show the "ok" sent back from the mega. It only gets one "ok" the one first sent by the mega to show it's ready to receive.
mega's (short) code:
#define BytesToWrite 16
byte pwmLevels[BytesToWrite];
int col, row;
unsigned int eepromPos=0;
void setup(){
flash13(9,50);
Serial.begin(19200);
Serial.print("ok");//Processing waits to get the "ok"
void loop(){
if (Serial.available() >= BytesToWrite){
flash13(1,50);
for (int i=0; i<BytesToWrite; i++){
pwmLevels[i] = Serial.read();
//pwmLevels[i] = c;
/*for (int i=0; i<BytesToWrite; i++){
Serial.print(pwmLevels[i],DEC);
Serial.print(" ");
// 0x50 is the eeprom's address if pins 1,2,3 are tied to ground or left floating.
//i2c_eeprom_write_byte( 0x50, eepromPos, c );//one byte at a time
i2c_eeprom_write_page( 0x50, eepromPos, pwmLevels, BytesToWrite );
eepromPos += BytesToWrite;
// delay(5);//allow eeprom to save buffered bytes
flash13(1,50);
Serial.print("ok");//"Processing" waits to get the "ok".
void flash13(int howManyTimes, int delayTime){//flash the led on pin13
for(int i=0;i<howManyTimes;i++){
digitalWrite(13,HIGH);
delay(delayTime);
digitalWrite(13,LOW);
delay(delayTime);
}//show the world we got here
Processing's (also short) code:
import processing.serial.*;
// used to send the mega bits of data to the arduino mega
Serial serialPort;
byte[] ByteShades = new byte[131072];
int ndxVar=0;//+- 2,147,483,648
String inString = "";
int BytesToSend = 16;
int lf=10;
PFont myFont;
size(500,200);
myFont = loadFont("BitstreamVeraSans-Bold-18.vlw");
textFont(myFont, 18);
serialPort = new Serial(this, "/dev/ttyUSB1", 19200);//"/dev/ttyUSB2"
//println("/dev/ttyUSB1");
ByteShades = loadBytes("Shades.dat");
serialPort.bufferUntil('k');
void draw() {
background(0);
if(inString.equals("ok")){
println(inString);
inString="";
sendBytes();
text("Sent: " + ndxVar+" bytes", 10,50);
void sendBytes(){
for(int j = 0; j < BytesToSend; j++){
serialPort.write(ByteShades[ndxVar]);
ndxVar++;
//print(ByteShades[ndxVar]+" ");
println("");
void serialEvent(Serial p) {
inString = (serialPort.readString());
Anyone like to see if they can make it work? I've tried for several days with no luck. I'm wondering if changes need to be made to the wiring library to make the mega1280 compatible. It could be the internal pulldowns aren't setting the correct address. I could bridge the pins to ground. Hate to, it looks nice right now!
