Writing and Reading Array's to an external SD card
I am currently busy on a prototype where the Arduino can identificate people using a fingerprint sensor and shows some information about this person like name and birthdate.
The fingerprint sensor does the fingerprint matching all by itself and the only output it gives is a ID-number, for example ID = 6.
I want to use this ID number to retrieve the personal information out of an array i saved on the SD card by using the script below
#include <SPI.h>
#include <SD.h>
File myFile;
String IDnr = "0";                        // Give ID number
String Firstname = "Mike";         // Give the first name.
String Lastname = "Mikeson";       // Give the last name
String Birthdate = "19-07-1956";  // Give the birth date (dd-mm-yy)
String PersonalData[4] = {IDnr, Firstname, Lastname, Birthdate}; // Array met persoonsgegevens
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  Serial.print("\n");
  if (!SD.begin(10)) { //CS is connected to pin 10
    Serial.println("initialization failed!");
    Serial.print("\n");
    return;
  Serial.println("initialization done.");
  Serial.print("\n");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("IDfile.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.println("IDfile.txt succesfully opened");
    Serial.print("\n");
    myFile.print(PersonalData[0]);
    myFile.print("; ");
    myFile.print(PersonalData[1]);
    myFile.print("; ");
    myFile.print(PersonalData[2]);
    myFile.print("; ");
    myFile.print(PersonalData[3]);
    // close the file:
    myFile.close();
    Serial.println("Saved");
    Serial.print("\n");
    // if the file didn't open, print an error:
    Serial.println("error opening IDalistic.txt");
  // nothing happens after setup
Now I can’t figure out the best way to retrieve the information using the ID number. Eventually it will store multiple entities and when I scan a finger I only want the personal information that is saved with the same ID number.
Any suggestions how I can achieve this?
