//simple button GET server code to control servo and arduino pin 5
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html
//for use with W5100 based ethernet shields
//Powering a servo from the arduino usually DOES NOT WORK.
//note that the below bug fix may be required
//http://www.instructables.com/id/Control-an-LED-over-the-internet-using-the-Arduino/step2/Connected/
// http://code.google.com/p/arduino/issues/detail?id=605
//http://www.instructables.com/id/Arduino-Control-via-a-Web-Service-with-Teleduino/?ALLSTEPS
//http://www.christophercommunications.org/Web_page_based_control.html
int A = 1;
int B = 2;
int C = 3;
int D = 4;
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 0, 177 }; // ip in lan
byte gateway[] = { 192, 168, 0, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
void setup(){
pinMode(6, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
//the pin for the servo co
//enable serial data print
Serial.println("server LED test 1.0"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<meta name='apple-mobile-web-app-capable' content='yes' />");
client.println("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
//client.println("<link rel='stylesheet' type='text/css' href='http://chriscosma.co.cc/a.css' />");
client.println("<TITLE>Home Automation</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Home Automation</H1>");
client.println("<hr />");
client.println("
//Light A
client.println("<a href=\"/?lightAon\"\">Turn On Light A</a>");
client.println("<a href=\"/?lightAoff\"\">Turn Off Light A</a>
//Light B
client.println("<a href=\"/?lightBon\"\">Turn On Light B</a>");
client.println("<a href=\"/?lightBoff\"\">Turn Off Light B</a>
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino Light A
if(readString.indexOf("?lightAon") >0)//checks for on
digitalWrite(A, HIGH);
Serial.println("Light A On");
client.println("<link rel='apple-touch-icon' href='http://shedbass.com/dtokez/buttons/on.png'/>");
else{
if(readString.indexOf("?lightAoff") >0)//checks for off
digitalWrite(A, LOW);
Serial.println("Light A Off");
client.println("<link rel='apple-touch-icon' href='http://shedbass.com/dtokez/buttons/off.png'/>");
///////////////////// control arduino Light B
if(readString.indexOf("?lightBon") >0)//checks for on
digitalWrite(B, HIGH);
Serial.println("Light B On");
else{
if(readString.indexOf("?lightBoff") >0)//checks for off
digitalWrite(B, LOW);
Serial.println("Light B Off");
//clearing string for next read
readString="";
Do you close the style tag with ? Can't see from here. But missing a closing tag is the sort of thing that will cause the rest of the page to get lost.
Ah! What a silly mistake, I forgot to close the tag as you say
many thanks!
I'm now attempting to show a different button by reading the state of a pin, but.... its not working lol
Just added this in, but neither image is showing up. When starting up the pin will be low, so I thought that the else if statement would run, which should display the on button, then once on the if loop would run, showing the off button?
maybe I have made another silly error, can't work out
int A = 6;
int B = 2;
int C = 3;
int D = 4;
#include <SPI.h>
#include <Servo.h>
byte mac[] = {
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
String readString;
void setup(){
//start Ethernet
server.begin();
void loop(){
if (client) {
readString += c;
//Serial.print(c);
if (c == '\n') {
client.println();
client.println("<style> body { background-color:#d0e4fe; }</style>");
//client.println("<H1>Home Automation</H1>");
//client.println("<hr />");
client.println("
//Light A
//client.println("Light A: ");
//client.println("<a href=\"/?lightAon\"\"><img src='http://www.shedbass.com/dtokez/buttons/on2.png'></a>");
//client.println("<a href=\"/?lightAoff\"\"><img src='http://www.shedbass.com/dtokez/buttons/off2.png'></a>
if(A == HIGH)
client.println("<a href=\"/?lightAoff\"\"><img src='http://www.shedbass.com/dtokez/buttons/off2.png'></a>");
else if(A == LOW)
//Light B
delay(1);
//stopping client
client.stop();
else{
else{
readString="";
It kind of looks like the browser is refreshing, but the button does not change, the current behavior is as follows:
First load of page= LED OFF, ON BUTTON DISPLAYED - correct
First click of button = LED ON, ON BUTTON DISPLAYED - incorrect
Second click of button = LED ON, OFF BUTTON DISPLAYED - incorrect
Third click of button = LED OFF, OFF BUTTON DISPLAYED - incorrect
Forth click of button = LED OFF, ON BUTTON DISPLAYED - correct
This is what I'm currently working with, and exhibiting the behaviour I explained above
int A = 6;
int B = 2;
int C = 3;
int D = 4;
#include <SPI.h>
//#include <Servo.h>
//Servo myservo; // create servo object to control a servo
byte mac[] = {
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
String readString;
void setup(){
//start Ethernet
server.begin();
void loop(){
if (client) {
readString += c;
//Serial.print(c);
if (c == '\n') {
client.println();
client.println("<style> body { background-color:#303030; }</style>");
client.println("
//Light A
client.println("<img src='http://www.shedbass.com/dtokez/buttons/hover.png'>");
if((digitalRead(A)) == HIGH)
else if((digitalRead(A)) == LOW)
//Light B
delay(1);
//stopping client
client.stop();
else{
else{
readString="";
If reading an OUTPUT pin doesn't result in HIGH, is there any possibility that the function will return something other than LOW?
Why are you reading from an OUTPUT pin? Surely you can (have the Arduino) remember what it set the pin to.
I'd suspect that you are running out of memory. Unpredictable things can happen when you are out of memory. The F() macro will cause all those massive literal strings from occupying both program memory (where they are OK) and SRAM (where they are not).
else{
I'm not sure of the issues associated with using the string class?
I have added a variable for pin state now - so hopefully it will store and read the state from there on the next loop?
I can't test at the moment as I'm at work, but it compiles so will flash the code tonight!
Thanks again!
//Define light output pins
int LightA = 6;
int LightB = 2;
int LightC = 3;
int LightD = 4;
//For holding pin state data
int LightAState = 0;
int LightBState = 0;
#include <SPI.h>
byte mac[] = {
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
String readString;
void setup(){
//Set up outputs
pinMode(LightA, OUTPUT);
pinMode(LightB, OUTPUT);
pinMode(LightC, OUTPUT);
pinMode(LightD, OUTPUT);
//Start Ethernet
server.begin();
void loop(){
if (client) {
readString += c;
//Serial.print(c);
if (c == '\n') {
client.println();
//Write head data
client.println("<style> body { background-color:#303030; }</style>"); //CSS style data
client.println("<TITLE>Home Automation</TITLE>"); //Page title
//Write body data
client.println("
//Light A
if(LightAState == HIGH)
else if(LightBState == LOW)
//Light B
delay(1);
//stopping client
client.stop();
///////////////////// control Light A
digitalWrite(LightA, HIGH);
LightAState = HIGH;
else if(readString.indexOf("?lightAoff") >0)//checks for off
digitalWrite(LightA, LOW);
LightAState = LOW;
///////////////////// control Light B
digitalWrite(LightB, HIGH);
LightBState = HIGH;
else if(readString.indexOf("?lightBoff") >0)//checks for off
digitalWrite(LightB, LOW);
LightBState = LOW;
readString="";
dtokez:
Since the problem appears to be in the behaviour of the browser when displaying your page, I suggest you post the HTML source of the page as received by the browser.
dtokez:
I see, so I can loose the F and the two brackets? What is the purpose of it?
Not loose them. Add them. The F() macros causes the literal string to remain in program memory, and enables access to the data from there, rather than allowing it to be copied to SRAM.
//for use with W5100 based ethernet shields//note that the below bug fix may be required
int LightA = 6;
int LightB = 2;
int LightC = 3;
int LightD = 4;
#include <SPI.h>
byte mac[] = {
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
String readString;
void setup(){
//Set up outputs
//Start Ethernet
server.begin();
void loop(){
if (client) {
readString += c;
//Serial.print(c);
if (c == '\n') {
client.println(F("HTTP/1.1 200 OK")); //send new page
client.println();
//Write head data
//Write body data
client.println("
//Light A
//Light B
//client.println("<a href=\"/?lightBon\"\">Turn On Light B</a>");
//client.println("<a href=\"/?lightBoff\"\">Turn Off Light B</a>
delay(1);
//stopping client
client.stop();
LightAState = HIGH;
LightAState = LOW;
LightBState = HIGH;
LightBState = LOW;
readString="";
