writing eeprom structure on ESP8266
Hi
have a question.
Want to write an EEPROM with structure.
How to set size of
EEPROM.begin()
can it only be a fix size or can
sizeof(structure)+1
be used?
Thanks
riker1:
Hi
have a question.
How to set size of
EEPROM.begin()
sizeof(structure)+1
be used?
Thanks
it can be the size of the structure
Hi
thanks
what happens if the size is changing while content of structure is changing?
epprom.begin(size)
has so be set for esp8266 I think.
I experienced that after writing the structure to eeprom.
I can not reboot and I have to flush it new.
Maybe any known problem?
Thanks T
Hi
looks like the restart problem is caused by an ESP problem.
You have to manually reboot it once after is it flashed.
otherwise ESP will not restart and esp.restart() ist not working and eeprom.write() as well....
just a hint.
not totally confirmed yet
riker1: Hi
just a hint.
after flashing, esp.restart() (soft-reset) returns to flashing mode. it is a bug of the esp8266. the esptool used in 2.5.0+ versions of the esp8266 arduino core invokes a hard reset after flashing to avoid this problem.
do you use EEPROM.end() or EEPROM.commit()?
Hi
I use eeprom.commit()
The idea of this EEPROM system is to limit the writes to the EEPROM, since it is using flash it would be a waste to use it for every single byte written.
understood, just using it for storing persistant configuration...so not often and only on demand
