Writing IF statement checking if Pin 6 is high
Hello,
I'm having trouble trying to synchronize pins 5&6 with an if statement. I would like for Pin 5 to go high&low when pin 6 does, but I'm having difficulty finding a solution for the syntax.
This is what I have so far.
pinMode(6, OUTPUT);
pinMode(5, OUTPUT);
digitalWrite(6, HIGH);
delay(3000);
digitalWrite(6, LOW);
if ((digitalRead(6)) == HIGH)
digitalWrite(5, HIGH);
else (digitalWrite(5,LOW));
Thanks in advance
When this statement is executed pin 6 will always be LOW because of the preceding statements
Why not simply set the pins to the same state at the same time as one another ?
  digitalWrite(5, LOW);
Why bother checking?
  digitalWrite(5, digitalRead(6));
But make sure 6 is an INPUT
You can read the state of an OUTPUT pin, but can you write successfully to an INPUT pin ?
Hard to guess what is required - I'm just checking out ideas.
kimibird47:
Whatever happens on pin 5 only happens after the one second delay. And, since when it gets to that point pin 6 is always LOW...
https://forum.arduino.cc/index.php?topic=484306.0
Using millis() for timing beginner’s guide
