Writing in to array
Hi gays…
needed your help in very simple problem
how to declarer and write in to a BYTE array???
http://arduino.cc/en/Serial/ReadBytes
here says that function: Serial.readBytes(buffer, length)
buffer: the buffer to store the bytes in (char or byte)
So char is works but byte aren’t
but I need exactly a byte not the char… Char give me garbidge…
What Im trying to do is reading the answer (series of bytes) from device…
char Str2[6]; works but getting garbidge
byte Str2[6]; – IDE won’t comply…
I don’t get why
this the code
char Str2[6];
byte ReqSld[] = {0x00, 0x04, 0x00, 0x04};
 for (int i=0;i<6;i++) Str2[i]=0;
         mySerial.write(ReqSld, sizeof(ReqSld));
          delay(10);
         mySerial.readBytes(Str2,6);          // (buff, size)
         int i;
         for(i=0; i<6; i=i+1)
            Serial.write(Str2[i]);        // it is write and also reads same way byte by byte
          Serial.println("");
//          R=mySerial.read();
//          Serial.println(R);
Common guys??? nobody have any solution to this?
b= byte (Str2[0]);
I found this... works but needs to put in the String some how
Hello,
I don't understand what you are trying to do with the device's reply. It's a sequence of bytes, but you want to store them in a string? Why?
And your code is really ugly, learn indenting, especially if you want people to review it...
But most importantly, it's really bad practice to just wait a certain time to then read a certain amount of data without even knowing if it arrived :P. See this example for a better way to do it.
Slavka85:
I don't get why
this the code
Because you didn't post a complete compilable program, neither do I.
There is no need to use readBytes()
See the Arduino code in this demo
...R
