So far it works fine, because I only needed to store bytes.
But now I want to store time in seconds, so I need to store a long.
I've found EEPROMWritelong and tried to use it for my external EEPROM:
void EEPROMWritelong(int deviceaddress, unsigned int eeaddress, long value) {
Wire.beginTransmission(deviceaddress);
byte four = (value & 0xFF);
byte three = ((value >> 8) & 0xFF);
byte two = ((value >> 16) & 0xFF);
byte one = ((value >> 24) & 0xFF);
Wire.write(eeaddress, four);
Wire.write(eeaddress + 1, three);
Wire.write(eeaddress + 2, two);
Wire.write(eeaddress + 3, one);
Wire.endTransmission();
delay(5);}
long EEPROMReadlong(int deviceaddress, long eeaddress) {
long four = Wire.read(address);
long three = Wire.read(address + 1);
long two = Wire.read(address + 2);
long one = Wire.read(address + 3);
return ((four << 0) & 0xFF) + ((three << 8) & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
But this gives an error:
call of overloaded 'write(unsigned int&, byte&)' is ambiguous
Can someone explain to me what this means, and how to solve it?
Coos:
No, sorry for the confusion, but I meant numbers from 0 to 254.
Since those values are all byte sized, I don't see the issue. Your second code breaks the long into 4 bytes. Write the 4 bytes, one at a time, just like you write the one byte.
PaulS:
Then why doesn't my second code compile?
Her is my entire code:
#include "Wire.h"
#define EEPROM_DEVICE_ADDRESS 0x50
unsigned int EEPROM_ADDRESS = 0;
Wire.begin();
// writeEEPROM(EEPROM_DEVICE_ADDRESS, EEPROM_ADDRESS, 123);
EEPROMWritelong(EEPROM_DEVICE_ADDRESS, 0, 43140);
void writeEEPROM(int deviceaddress, unsigned int eeaddress, byte data ) {
Wire.write((int)(eeaddress >> 8)); // MSB
Wire.write((int)(eeaddress & 0xFF)); // LSB
Wire.write(data);
delay(5);
byte readEEPROM(int deviceaddress, unsigned int eeaddress ) {
byte rdata = 0xFF;
Wire.requestFrom(deviceaddress,1);
if (Wire.available()) rdata = Wire.read();
return rdata;
void EEPROMWritelong(int deviceaddress, unsigned int address, long value) {
Wire.write(address, four);
Wire.write(address + 1, three);
Wire.write(address + 2, two);
Wire.write(address + 3, one);
delay(5);
long EEPROMReadlong(int deviceaddress, long address) {
Serial.println(readEEPROM(EEPROM_DEVICE_ADDRESS, EEPROM_ADDRESS), DEC);
delay(1000); // every second
If you're uncomfortable with bit-shifting, you could use a union:
union {
byte val[sizeof(long)];
long number;
} myUnion;
// ...some code...
int i;
long valueToSave = 123L;
myUnion.number = valueToSave; // Shove into the union...
for (i = 0; i < sizeof(long); i++){
Wire.write(baseAddress + i, myUnion.val[i]); // Assume baseAddress set somewhere...
