Writing on file SD card
Hello,
I am trying to writing in a txt file in this way:
int ans[10]; int q=0;
out_file.write((uint8_t )current->id);
       out_file.print("\n");
        ans[q] = current->id;
        q++;
when I open the file, I got on unreadable data but when I print the array I can read the data without any error.
Is my writing in file wrong?
Post ALL the code. Usually, nothing useful can be concluded from a snippet.
I can't, it very longs code!
I can't
Yes, you can. Use code tags, as explained in the "How to get the best out of this forum" post.
However, if you have a problem with code, the best approach is to post the minimal complete example code required to reproduce the problem.
I worked when I use out_file.print()
But I need to use write()
why?
