Writing only used bytes instead of all, how? I2C
So I’m having a little issue with my third I2C build.
I have the code attached below and it uses a “buffer” of 133 bytes.
But if I write for example “HELLO” that uses only 25 bytes, but my code still pushes out 133.
The rest are pushed out as 0x00. How do I avoid this?
Any help or tips are welcome
  byte Display[133] = { dev, 0xF0, x }; //Device, 240, X-Position
  byte len = (strlen(character));
  for (uint8_t i = 3; i <= len * 5; i += 5 , character++)
    memcpy (Display + i, &_ASCIIchars[(int)*character][0], 5);
  Wire.beginTransmission(_Addr);
  Wire.write(Display, sizeof(Display));
  Wire.sendTransmission();
  delay(50);
You have
and
Could it be that sizeof(Display) is 133 bytes? What should go here instead?
character is a stupid name for an array. It implies a single character, but, clearly, it is used as an array.
Why are you diddling with the address of the array?
What, exactly, are you multiplying character by? Why?
vaj4088:
WOW! I'm obviously way to tired to do this right now! But Thanks a billion!
Wire.write(Display, (3+(len*5)));
PaulS:
Character is the input, output is the bytes for the display driver. " Lets be a little positive? :slight_smile: "
And to know the bytes I have a lookup array for the character.
So if input is char("H"), output from that array would be {0xFE, 0x10, 0x10, 0x10, 0xFE}
OK. I'm POSITIVE that you need to post ALL of your code!
