How can I take readings displayed in the serial monitor and display them on the screen? Instead of text, I want to display the temperature. Partially completed below:
If you do a successful verify, you can highlight the display library (U8g2kib), then right click and select Go to Definition. Now you can see what all the member functions are. You probably want something like write, but before that some sort of positioning call like row and col and of course clear the old display first.
What I do in these cases is goto the library manager entry for the library and click the 3 dots beside the name then select examples.
I'm sorry but I don't really understand. I found a tool to scan the device address but I don't know how to use it. How do I turn the data it's collecting into something that u8g2 can print to screen?
I have the temperature as some float value. What do I do with it for u8g2 to display it?
