Writing the value in an ESP8266 variable from a JavaScript variable
Hello everybody.
I have a question about the use of html input value.
How can I get a value from a JavaScript or HTML variable and write this value in a ESP-8266 variable?
I putted in red the method that I trying use.
Follow part of code:
// Load Wi-Fi library
#include <ESP8266WiFi.h>
float temp_dia[32] = {0.0, 1.1, 2.2, 3.3, 4.4, 5.5, 6.6, 7.7, 8.8, 9.9, 10.0, 11.1, 12.2, 13.3, 14.4, 15.5, 16.6, 17.7, 18.8, 19.9, 20.0, 21.1, 22.2, 23.3, 24.4, 25.5, 26.6, 27.7, 28.8, 29.9, 30.0, 31.1 }; //array que guarda os valores das temperaturas por dia
String temp_dia_html[32];
float contagem = 10.4;
float temp_atual = 11.3;
float temp_ref = 15.0;
int dia = 1;
float tolerancia = 0.5;
String data_html = "15/8/18";
String hora_html = "22:03";
String status_resfriando_html = "OFF";
String status_aquecendo_html = "OFF";
int status_iniciar = 0;
int status_gravar = 0;
// Replace with your network credentials
const char* ssid = "testeonoff";
const char* password = "12345678";
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
//Função para converter temperatura dos dias de float para string
void converter_float_para_html()
for (int contador=1; contador<=31; contador ++)
temp_dia_html[contador]=String (temp_dia[contador],1);
void loop(){
contagem = contagem + 0.1;
if (contagem > 100){contagem =0.0;}
String temperatura_html = String(contagem, 1);
String temp_atual_html = String(temp_atual, 1);
String temp_ref_html = String(temp_dia[dia], 1);
//String temp_ref_html = String(temp_ref, 1);
String dia_html = String(dia);
String tolerancia_html = String(tolerancia, 1);
WiFiClient client = server.available(); // Listen for incoming clients
if (client) { // If a new client connects,
Serial.println("New Client."); // print a message out in the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
header += c;
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
// turns the GPIOs on and off
if (header.indexOf("GET /iniciar") >= 0) {
Serial.println("iniciar");
status_iniciar =1;
status_resfriando_html = "ON";
if (status_iniciar == 1){
client.println("");
status_iniciar = 2;
} else if (header.indexOf("GET /5/off") >= 0) {
Serial.println("GPIO 5 off");
status_iniciar =0;
} else if (header.indexOf("GET /gravar") >= 0) {
Serial.println("gravar");
status_gravar =1;
if (status_gravar == 1){
client.println("");**
** client.println("");**
status_gravar = 0; //2
dia++;
if (dia>31){dia=1;}
if (status_aquecendo_html == "ON"){status_aquecendo_html = "OFF";} else
status_aquecendo_html = "ON";
// Display the HTML web page
client.println("");
client.println("<meta name="viewport" content="width=device-width, initial-scale=1">");
client.println("<meta http-equiv='content-type' content='text/html' charset='UTF-8'>");
client.println("<link rel="icon" href="data:,">");
exemplo-on-off_v7.ino (12.5 KB)
you know that the script executes in browser on a different device?
