Hello I want to send the information of an analog input to three channels simultaneously. For example with a mpxv5004 sensor to control three midi output channels please guide me since I can't control more than one channel
The goal is to figure out how to send a signal to multiple channels at a time.
Split from an old thread
vahidvzv:
Post the code you have that controls one channel the way you want it to. Adding a couple of extra writes to other channels should be simple but will depend on what code you're using now.
Steve
There are 4 MIDI send commands in there. What happens if you just add extra commands after each existing MIDI.sendxxxxxxxx() identical except with the 3rd parameter set to 2 or 3 instead of 'channel' as now? E.g.
MIDI.sendControlChange(CC_Number, breathCC, channel);
MIDI.sendControlChange(CC_Number, breathCC, 2);
MIDI.sendControlChange(CC_Number, breathCC, 3);
Repeat for the other MIDI commands.
Steve
slipstick:
4 دستور ارسال MIDI در آنجا وجود دارد. چه اتفاقی می افتد اگر فقط بعد از هر MIDI موجود دستورات اضافی اضافه کنید .sendxxxxxxxx () به جز پارامتر 3 که به جای "channel" در حال حاضر روی 2 یا 3 تنظیم شده است؟ به عنوان مثال تکرار برای دستورات MIDI دیگر. استیوMIDI.sendControlChange(CC_Number, breathCC, channel);
آیا می توان همزمان با یک کد کوچک خروجی یکسانی بر روی USB داشت؟
Reported to moderator as follows
Reported by vahidvzv on Today at 05:13:21. They left the following message:
Thank you very much. The channel problem was fixed thanks to your help
Yet another spurious "Report to moderator", this time by @hanszull
apart from mpxv4006gp and mpx5010gp, what type of sensor can you use?
