Writing to Arduino using R
I have an Arduino (Uno) connected to a macbook on MacOS 10.14 using USB and I am trying to exchange data using R.
Setting up a connection and reading data works fine, but writing data provokes an error and I am not sure what’s wrong. A working example:
#loading the R package for serial communication
require(serial)
#storing the appropriate serial device name
con_dir = "/dev/"
con_arduino_cu<-list.files(con_dir, pattern ="cu.usb")
#setting up connection parameters, making sure the BAUD rate matches the one used by the Arduino
con <- serialConnection(name = "testcon"
                       ,port = con_arduino_cu
                       ,mode = "9600,n,8,1"
                       ,buffering ="none"
                       ,newline = 1
                       ,translation = "cr"
#opening and testing the connection
open(con)
isOpen(con)
#this reads that from the Arduino
read.serialConnection(con)
#But this returns an error: 'Error: [tcl] can't read "tcl_tmp_cu": no such variable'
write.serialConnection(con,"Hello world")
I have tried using the ttl connection instead of the cu connection, but this makes R hang.
Any idea on whats wrong, or for alternative ways to write data over USB?
I am not sure what you expect with posting R code.
We don't use it here.
Have no idea what a "cu connection" is either.
This is (now?) in the "interfacing section" so any computer language should be OK.
OP might be better of in a forum for the specific language though.
OP, does your Arduino code work with a normal terminal program (e.g. serial monitor)?
