Hello!
I want to set my NRF24L01+ to use 250kbps transmission rate, and I'm using Mirf to communicate with it.
The datasheet says:
RF_SETUP 0x06
(RF_DR_LOW) bit 5: Set RF data rate to 250kbps. See RF_DR_HIGH fo enconding.
(RF_DR_HIGH) bit 3: Select between the high speed data rates. This bit is don't care if RF_DR_LOW is set. Encoding: 00 - 1Mbps, 01 - 2Mbps, 10 - 250kbps, 11 - reserved
So basically if I write a 1 to RF_DR_LOW I will get 250kbps?
Also, RF_PWR can be 0, -6, -12, -18dBm, which of these are the highest power?
Kalveo:
Hello!
I want to set my NRF24L01+ to use 250kbps transmission rate, and I’m using Mirf to communicate with it.
The datasheet says:
RF_SETUP 0x06
(RF_DR_HIGH) bit 3: Select between the high speed data rates. This bit is don’t care if RF_DR_LOW is set. Encoding: 00 - 1Mbps, 01 - 2Mbps, 10 - 250kbps, 11 - reserved
