Writing to RAM in arduino duemilanove- atmega 328P
Hey
How much time does it take to write to RAM of Arduino duemilanove( atmega 328p). I know it takes 3.3 ms to write 1 byte to EEPROM but couldnt find about RAM
thanks
62.5ns
1 byte for 62.5 ns?
How did you get that? I mean does it depend upon 16Mhz crystal?
I mean 1 clock cycle is required for 1 bit writing?
I understand you took timeperiod of clock pulse 16MHz?
Yes.
No. One clock cycle to write one byte.
Also Does arduino duemilanove supports baudrate to be 14400 in serial.begin(14400)?
I am getting correct reading at 9600 but not at 14400? I just gives 111111111
Yes, it does.
Fix line 27.
Line 27 my side is SPI.transfer(33)?
What is wrong with it?
What's wrong is that we can't see your code.
Classic. :slight_smile:
Graynomad:
It was bound to happen sooner or later
Hey sorry
I posted the code on other post which paul was already following and earlier asked me to share code.
Thats why I wrote. Let me uplaod the code once again here.
#include "SPI.h"
int ss=10;
unsigned int adcValue=0;
byte highByte;
byte lowByte;
long previousMillis=0;
long interval=1000;
unsigned int adcValue1[500];
unsigned int k=0;
  pinMode(ss, OUTPUT);   // setting SS pin as output
  SPI.begin();
  SPI.setBitOrder(MSBFIRST);
  SPI.setClockDivider(SPI_CLOCK_DIV2);
  //series of command bit
  digitalWrite(ss,LOW); // Selecting chip by making CS low
  SPI.transfer(32);     //command for comm reg to select ch1 and write to clock register
  SPI.transfer(167);    //command for clock reg to set 2,4576Mhz
  SPI.transfer(16);     //command for comm reg to write setup register
  SPI.transfer(68);     //command for setup reg to self calibration,unipolar,unbuffered
 char DataNotReady = 128;
      while(DataNotReady) // wait for end of conversion
          SPI.transfer(8);//command for comm reg to read  (dec   8)
          DataNotReady =SPI.transfer(0); // Read comm register
          DataNotReady &= 0x80; //Hexadecimal of 128
  SPI.transfer(33);    //command for comm register to select ch2 and write to clock register
  SPI.transfer(167);    // command for clock register to set 2.4576 Mhz
  SPI.transfer(17);  //command for the comm register to write setup for channel 2
  SPI.transfer(68);  //command for set up register to self calibrate,unipolar,unbuffered
   char DataNotReady1 = 128;
      while(DataNotReady1) // wait for end of conversion
          SPI.transfer(9);//command for comm reg to read  (dec   8)
          DataNotReady1 =SPI.transfer(0); // Read comm register
          DataNotReady1 &= 0x80; //Hexadecimal of 128
  while(1)
  {   for(int ch=1; ch<=2;ch++)
      { if(ch==1)
         else if(ch==2)
         { SPI.transfer(9);
	 //read 16bit of data ADC
	 highByte = 0;
	 lowByte = 0;
         if(ch==1)
         SPI.transfer(56); // inform the adc that you will be  reading the data register in the next operation
         else if(ch==2)
         { SPI.transfer(57);
	 highByte = SPI.transfer(0);
	 lowByte = SPI.transfer(0);
	 adcValue = highByte << 8;
	 adcValue = adcValue | lowByte;
         Serial.println(adcValue,DEC);
   /*     adcValue1[k]=adcValue;
         k++;
         unsigned long currentMillis= millis();
         if(currentMillis- previousMillis > interval)
          { Serial.println(k,DEC);
            previousMillis=currentMillis;
           for(int i=0; i<500;i++)
            Serial.println(adcValue1[i],DEC);
	// Serial.print("analog value =");
	// Serial.println(adcValue, DEC);
	// Serial.print('\n');
	 //delay(1000);
PaulS:
Yes, it does.
Does SerialMonitor support 14400 ?
I fear there's the problem: just use 57600 or 115200, if 9600 should be too slow for you.
Read its output more carefully, then 9600 is fast enough :wink:
actually 9600 is good but i want more datapoints per sec So i thought my reading of comm port may be slow. So i increased baud rate. 14400 just prints 11111111111111111.... and 19200 giver incorrect datapoints.
Some of the intermediate Baud rates you can choose in SerialMonitor, do not work.
If you'd use another Serial program on the PC , which definitely supports 14400, it should work with an Arduino set to that Serial speed.
Does it happen with a pure test sketch?
Serial.begin(14400);
Serial.println ("ABCDEFGHIJKLMNOPQRSTUVWXYZ");
   static unsigned long m;
   if (millis() - m >= 60000UL) {
       m = millis();
       Serial.write('.');
should produce 4 identical correct lines. Then a dot every minute.
Perhaps there's something really wrong with the Arduino's speed: How long does it really take to wait until millis() is at 1800000L
Should be between 29 and 31 Minutes for 30 dots from the test sketch above.
