I am working with MKR GSM 1400 to upload file to FTP server from Sdcard interfaced to the board. I read the data sheet of GSM modem SARA-U201 and found that first you have to create a file in U201 file system and then transfer to FTP server. I am able to create and write to the file system of U201 but it takes around 7-8 minutes to copy data from SDCARD to gsm modem file system for 1MB file. Can anyone tell me faster way to copy data.
#include <SPI.h>
#include <SD.h>
unsigned long baud = 19200;
bool debug = 1;
char* file_name1 = "REC00000.wav";
File File1;
int file_size_sd;
long int bytes;
pinMode(2, OUTPUT);
while (!Serial)
; // wait for serial port to connect. Needed for native USB port only
pinMode(GSM_RESETN, OUTPUT);
digitalWrite(GSM_RESETN, HIGH);
delay(100);
digitalWrite(GSM_RESETN, LOW);
delay(5000);
Serial.begin(baud);
SerialGSM.begin(baud);
if (!SD.begin(2)) {
Serial.println("Initialization failed!");
return;
while(true);
}else {
Serial.println("Initialization done.");
File1 = SD.open(file_name1);
if (File1) {
Serial.println("Opening the file: " + String(file_name1) + " done.");
}else {
Serial.println("Error opening " + String(file_name1));
while(true);
if (File1) {
int i = 0;
file_size_sd = File1.size();
Serial.println(file_size_sd);
sendATcommand("AT+ULSTFILE=","OK", 1000); //List all the files in the file system
sendATcommand("AT+ULSTFILE=1","OK", 1000); //get free space in file system
sendATcommand("AT+UDWNFILE=\"sound.wav\",2000000","OK", 1000); //create a file in gsm file system
Serial.println("Copy file data");
while (File1.available()>0) {
SerialGSM.write(File1.read());
delay(2000);
Serial.println("Done Writing");
File1.close();
unsigned char sendATcommand(char* ATcommand, char* expected_answer1, unsigned int timeout) {
unsigned char x = 0;
unsigned char answer = 0;
char response[100];
unsigned long previous;
memset(response, '\0', 100);
delay(100);
while( SerialGSM.available() > 0) SerialGSM.read();
SerialGSM.println(ATcommand);
x = 0;
previous = millis();
do{
if(SerialGSM.available() != 0){
response[x] = SerialGSM.read();
x++;
if (strstr(response, expected_answer1) != NULL) {
answer = 1;
} while((answer == 0) && ((millis() - previous) < timeout));
if (debug) {Serial.println(response);}
return answer;
