Writing to serial LCD seems to interfere with servos
I have an OBD-based Arduino project (OBD adapter link below) which uses two servos and a serial LCD from Sparkfun (link below). My problem: writing to the LCD seems to interfere with the servos. Details:
  1. When all LCD-related code is excluded, the servos work smoothly.
  2. When LCD-related code is included, but the servos are not hooked up, the LCD displays everything OK.
  3. When the LCD-related code is included, even if the LCD itself is NOT hooked up, the problem occurs. There’s a brief noise from the servos every time I write to the LCD (the servos don’t move much, they just make a brief noise).
Any idea what’s causing this? Below are the relevant parts of the code (OBD, servo, LCD):
#include <Arduino.h>
#include <Wire.h>
#include <OBD.h>
#include "MPU6050.h"
#include <SoftwareSerial.h>
#include <Servo.h>
int servoPin1=13;
int servoPin2=12;
Servo servo1;
Servo servo2;
COBDI2C obd;
SoftwareSerial lcd(2,3);
void clearDisplay() {
  lcd.write(0xFE);
  lcd.write(0x01);
void setLCDCursor(byte cursor_position) {
  lcd.write(0xFE);
  lcd.write(0x80);
  lcd.write(cursor_position);
void Show() {
  setLCDCursor(0);
  lcd.print("Test");
  lcd.begin(9600);
  clearDisplay();
  setLCDCursor(0);
  lcd.print("OBD");
  pinMode(servoPin1,OUTPUT);
  pinMode(servoPin2,OUTPUT);
  servo1.attach(servoPin1);
  servo2.attach(servoPin2);
  servo1.write(0);
  delay(200);
  servo2.write(100);
  delay(200);
  obd.begin();
  conn=obd.init(PROTO_AUTO);
  lcd.print("Connected");
  Wire.begin();
  conn=obd.readPID(PID_RPM,rpm);
  if (condition) {
    servo2.write(50);
    servo1.write(100);
  Show();
OBD adapter: Freematics – Freematics OBD-II I2C Adapter for Arduino
Serial LCD [: https://www.sparkfun.com/products/10097](http://: https://www.sparkfun.com/products/10097)
This is a commonly encountered problem. The SoftwareSerial library disables interrupts while characters are being sent, the servo library relies on interrupts. So there is a conflict between the two libraries.
If you Google the problem you will find there are a few solutions using different library combinations.
Thanks, I didn't know it was a known problem. I'll Google it.
