Hi, I'm trying to write to the Uno's EEPROM using this code - http://forum.arduino.cc/index.php/topic,41497.0.html. However, I'm getting compile errors saying this,
C:\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino\hardware\arduino\cores\arduino -IC:\Arduino\hardware\arduino\variants\standard -IC:\Arduino\libraries\EEPROM C:\Users\Hrishi\AppData\Local\Temp\build33658092254607944.tmp\ReadWriteAnything.cpp -o C:\Users\Hrishi\AppData\Local\Temp\build33658092254607944.tmp\ReadWriteAnything.cpp.o
ReadWriteAnything:4: error: expected ',' or '...' before '&' token
ReadWriteAnything:4: error: ISO C++ forbids declaration of 'T' with no type
ReadWriteAnything:5: error: 'T' has not been declared
ReadWriteAnything.ino: In function 'int EEPROM_writeAnything(int, const T&) [with T = byte]':
ReadWriteAnything.ino:30: instantiated from here
ReadWriteAnything.ino:7: warning: comparison between signed and unsigned integer expressions
ReadWriteAnything.ino: In function 'int EEPROM_readAnything(int, T&) [with T = byte]':
ReadWriteAnything.ino:35: instantiated from here
ReadWriteAnything.ino:16: warning: comparison between signed and unsigned integer expressions
ReadWriteAnything.ino: In function 'int EEPROM_writeAnything(int, const T&) [with T = long int]':
ReadWriteAnything.ino:44: instantiated from here
ReadWriteAnything.ino: In function 'int EEPROM_readAnything(int, T&) [with T = long int]':
ReadWriteAnything.ino:49: instantiated from here
ReadWriteAnything.ino: In function 'int EEPROM_writeAnything(int, const T&) [with T = st_t]':
ReadWriteAnything.ino:65: instantiated from here
ReadWriteAnything.ino: In function 'int EEPROM_readAnything(int, T&) [with T = st_t]':
ReadWriteAnything.ino:74: instantiated from here
This is the code I'm using,
#include <EEPROM.h>
template <class T> int EEPROM_writeAnything(int ee, const T& value)
const byte* p = (const byte*)(const void*)&value;
int i;
for (i = 0; i < sizeof(value); i++)
EEPROM.write(ee++, *p++);
return i;
template <class T> int EEPROM_readAnything(int ee, T& value)
byte* p = (byte*)(void*)&value;
int i;
*p++ = EEPROM.read(ee++);
return i;
struct st_t {long lo; byte by; double db;};
int n = 0;
byte by = 0x33;
Serial.println(by, HEX);
n = EEPROM_writeAnything(0, by);
Serial.print("Wrote bytes: ");
Serial.println(n);
by = 0xFF;
n = EEPROM_readAnything(0, by);
Serial.print("Read bytes: ");
Serial.println(n);
Serial.println("-------");
long lo = 0xDEADBEEF;
Serial.println(lo);
n = EEPROM_writeAnything(23, lo);
Serial.println(n);
lo = 0xFFFFFFFF;
Serial.println(lo);
n = EEPROM_readAnything(23, lo);
Serial.println(n);
Serial.println(lo);
double pi = 3.1415926538;
struct st_t st;
st.lo = 0xABADF00D;
st.by = 0x22;
st.db = pi;
Serial.println(st.lo);
Serial.println(st.by, HEX);
Serial.println(st.db == pi);
n = EEPROM_writeAnything(221, st);
Serial.println(n);
st.lo = 0xFFFFFFFF;
st.by = 0x11;
st.db = 0.0;
n = EEPROM_readAnything(221, st);
Serial.println(n);
//nothing to do here
Can anyone please help me sort this out?
